scat 4.5 crank
+14
J.Toney
powerstrokeace
mikey hefner
nitrous.f
kim
MustangDan
18 posters
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: scat 4.5 crank
MustangDan wrote:Well a lot of people are telling me scat cranks and rods are really not good after 100hp ?
A 100HP?
Ace
powerstrokeace- Posts : 1496
Re: scat 4.5 crank
Yeah 100 hp man lol
MustangDan- Posts : 140
Re: scat 4.5 crank
Who is "a lot of people" ?
Any chance some of them are in biz selling other brand cranks?
My 598 is well over 1000 hp NA and has been sprayed another 300 on top of that. Scat forging and h beams with upgraded bolts.
There are numerous members here with 1000 hp Scat deals.
Re: scat 4.5 crank
hope its not the same folks claiming a back cut set of SCJ's will outflow a set of P 51s??????
Re: scat 4.5 crank
Well it depends on what you mean buy out flow if you port scj they will out flow stock p51 but both ported will p wins
Re: scat 4.5 crank
And no its people that has built and raced a lot of bbf scj flow 411@700 ported box p flow 360 ish out the box
Re: scat 4.5 crank
thats funny, Kasse lists the p51 as flowing 401 at .700 lift...... out of the box
Re: scat 4.5 crank
I was just on his page did see that at all
Re: scat 4.5 crank
Just looked again 395@800 int 239@800 exh and both stock p51 don't get any better till .500lift and that's on kasse page
Re: scat 4.5 crank
The Best Flowing, Most Powerful, User Friendly 429-460 Wedge Cylinder heads on the Market!
THE BEST COBRA JET STYLE CYLINDER HEADS ON THE MARKET!
Specifications:
• 72cc CNC MACHINED CHAMBERS
• INTAKE RUNNER VOLUME 310CC
• EXHAUST PORT VOLUME 145CC
• INTAKE VALVE DIAMETER 2.250
• EXHAUST VALVE DIAMETER 1.760
• VALVE LENGTH (INT./EXH.) 5.365 / 5.150
• INTAKE VALVE ANGLE 8.3 DEGREES
• INTAKE VALVE CANT 4.7 DEGREES
• EXHAUST VALVE ANGLE 4.0 DEGREES
• EXHAUST VALVE CANT 3.2 DEGREES
• SPRING DIAMETER 1.550
• VALVE GUIDE 11/32
Flow Chart as Delivered @ 28" Superflow 600
P51
Intake .100 105
.200 175
.300 258
.400 330
.500 375
.600 395
.700 401
Exhaust .100 103
.200 137
.300 170
.400 199
.500 223
.600 242
.700 251
PRICING:
• BARE CYLINDER HEADS $845.00 EACH
Specifications:
• VALVE GUIDE 11/32
P51
Intake .100 105
.200 175
.300 258
.400 330
.500 375
.600 395
.700 401
Exhaust .100 103
.200 137
.300 170
.400 199
.500 223
.600 242
.700 251
PRICING:
Re: scat 4.5 crank
scroll down a little further and look where they compare them to the Super Cobra Jet head and don't say those numbers 395@800
Re: scat 4.5 crank
MustangDan wrote:scroll down a little further and look where they compare them to the Super Cobra Jet head and don't say those numbers 395@800
IF you are gonna base your engine and simply race the highest air-flow numbers, you will be a loser from the start.
Re: scat 4.5 crank
I'm not even using scj or p I have a460 I'm just saying what the flow chart says against each other on that page scj will flow more then p ported scj ported v/s box p51 scj flow more
Re: scat 4.5 crank
I've enjoyed watching this thread de-rail! And I'm no engineer/builder, but I sure don't see many SCJ's builds posting power #'s topping the P-51's, OTB or otherwise. From what I've learned, the p-51 is modeled AFTER a modified SCJ in the first place, it would only make sense that this is a step up the ladder as far as airflow quality and #'s go.
J.Toney- Posts : 398
Re: scat 4.5 crank
J.Toney wrote:I've enjoyed watching this thread de-rail! And I'm no engineer/builder, but I sure don't see many SCJ's builds posting power #'s topping the P-51's, OTB or otherwise. From what I've learned, the p-51 is modeled AFTER a modified SCJ in the first place, it would only make sense that this is a step up the ladder as far as airflow quality and #'s go.
AND,valve train geometry AND, combustion chamber shape AND, casting thickness integrity - to mention some other upgrades.
Re: scat 4.5 crank
. The worst I have seen is high 380s and it takes very little porting to get them to 411.MustangDan wrote:And no its people that has built and raced a lot of bbf scj flow 411@700 ported box p flow 360 ish out the box
Re: scat 4.5 crank
seems legit......
Re: scat 4.5 crank
FYI.....
http://www.460ford.com/forum/showpost.php?p=1086145&postcount=20
Lunati
Scat
RPM
Lunati
Scat
RPM
Carl- Posts : 284
Re: scat 4.5 crank
Big difference in cosmetics........ The Lunati looks nice.
Re: scat 4.5 crank
IDT-572 wrote:Big difference in cosmetics........ The Lunati looks nice.
They are.
I have several in stock. If anyone has a picture of a Scat crank to post, I can orient the Lunati in the same fashion and take a picture.....call it a virtual side by side comparison.
Carl- Posts : 284
Re: scat 4.5 crank
The last three crankshafts I have sold were forged Lunati....the finish of them is very nice.
Re: scat 4.5 crank
rmcomprandy wrote:AND,valve train geometry AND, combustion chamber shape AND, casting thickness integrity - to mention some other upgrades.
What was changed on the valvetrain geometry? I've seen the P51 and SCJ guideplates side by side and they look similar but one wouldn't bolt to the other head and vice versa. How far are the valves moved around?
jbozzelle- Posts : 3705
Re: scat 4.5 crank
jbozzelle wrote:rmcomprandy wrote:AND,valve train geometry AND, combustion chamber shape AND, casting thickness integrity - to mention some other upgrades.
The valves are not moved but, they are longer and the studs are at a slightly different angle which is why a different "girdle" is necessary.
Re: scat 4.5 crank
I bet varleys scj headed 52x is faster then hEros black bullet...............
85bigblockfox- Posts : 241
» How to tell if a motor is externally or internally balanced
» Revised : WTB parts list
» SCAT CRANK KEY"S
» IDT Block & Scat 4340 crank ?
» scat 9000 crank
» SCAT CRANK KEY"S
» scat 9000 crank
Page 2 of 3
