What octane
What octane
As far as BBF's go how do you figuer what octane to use I know iron heads and aluminum heads change what octane you can use is there a chart or formula you can use or is it just trial and Era. I'm sure there's a point where your wasting money on higher octane and dont need it. Say you have 11:1 could you start out with 110 octane tune your motor timing ect. And then don't change anything and start dropping 2 points of octane at a time till it pings or is there a better way to get the right octane with your combo thanks
Super Snake Steve- Posts : 141
Re: What octane
Super Snake Steve wrote:As far as BBF's go how do you figuer what octane to use I know iron heads and aluminum heads change what octane you can use is there a chart or formula you can use or is it just trial and Era. I'm sure there's a point where your wasting money on higher octane and dont need it. Say you have 11:1 could you start out with 110 octane tune your motor timing ect. And then don't change anything and start dropping 2 points of octane at a time till it pings or is there a better way to get the right octane with your combo thanks
Both of the highlighted phrases should not be included in your project plan.
Dave.
LivermoreDave- Posts : 972
» What octane should I ran in my 460 with 10:1
» 112 octane too much??
» chassis Dyno Results and problems
» octane boost
» What octane for 14:1cr
» octane boost
