112 octane too much??
1Bad91
112 octane too much?? Empty 112 octane too much??
Post  1Bad91 July 25th 2010, 6:06 pm
Just curious if a 10:1 motor needs this octane to spray N20?
1Bad91
1Bad91
112 octane too much?? Empty Re: 112 octane too much??
Post  bruno July 25th 2010, 6:20 pm
1Bad91 wrote:Just curious if a 10:1 motor needs this octane to spray N20?
yes and it all depends on how much you will be hitting her with ...
http://WWW.CKRME.COM
Post  1Bad91 July 25th 2010, 6:34 pm
125-225...progressively
1Bad91
1Bad91
Post  bruno July 25th 2010, 6:41 pm
1Bad91 wrote:125-225...progressively
i would think ( which might be a bad thing ) with the iron heads i would try and use 114-116 ....
Post  Lem Evans July 25th 2010, 6:44 pm
I'm not a NOS guy but, I'd have to say I would depend on how much timing was pulled if/when the amount of NOS goes up.
Post  DFI429 July 25th 2010, 6:47 pm
Stock bottom end 429 11:1, D0VE-C, mild 275/285 cam w/150 shot on VP Red - never any problem - pump gas on the street
FWIW
DFI429
DFI429
Post  1Bad91 July 25th 2010, 7:43 pm
DFI429 wrote:Stock bottom end 429 11:1, D0VE-C, mild 275/285 cam w/150 shot on VP Red - never any problem - pump gas on the street
FWIW
VP red is what octane?
1Bad91
1Bad91
Post  Barney July 25th 2010, 9:08 pm
That combo could run on pumpgas w/ a conservative tune, anything more than 110 when spraying it may actually slow the car down. Your not spraying a ton so you could actually mix 110 and 93 and youll be fine.
Barney
Barney
Post  1Bad91 July 26th 2010, 2:32 pm
Barney wrote:That combo could run on pumpgas w/ a conservative tune, anything more than 110 when spraying it may actually slow the car down. Your not spraying a ton so you could actually mix 110 and 93 and youll be fine.
So if I have only 5 gallons of 112 in the car, how much 93 could I mix with it?
1Bad91
1Bad91
Post  G-Code July 26th 2010, 3:49 pm
FYI, from another question of yours VP-Red is 105 octane. Is the 112 you mention 112 octane or C-12? ( C-12 is 108 octane)
Mix your fuel 50/50 is fine. At your compression and the size shot you don't need to better gas, but it's not going to harm you either. I think your system would run okay with out it, but blending it is not a bad idea. 50/50 blend
G-
Post  1Bad91 July 26th 2010, 4:55 pm
Well, thats not so bad after all.....5 gallons of expensive stuff mixed with some 5 gallons of 93. I can deal with that
1Bad91
1Bad91
