Can a holley main body be welded ?
nuclearcobra
Can a holley main body be welded ? Empty Can a holley main body be welded ?
Post  nuclearcobra January 4th 2014, 3:21 pm
I have a carb that the post office beat to death and bent the linkage which I can bend back, but they also tore the vent tube out of it which split the vent tube boss , just wondering if it can be tig welded ? , vs. the old jb weld fix.
nuclearcobra
nuclearcobra
Can a holley main body be welded ? Empty Re: Can a holley main body be welded ?
Post  69F100 January 4th 2014, 5:25 pm
as long as you can get all the finish off and it is very very very clean where it needs welding unclean aluminum don't weld to good
Post  Mustang-junky January 4th 2014, 7:21 pm
I thought the main bodies were Zinc?
Jess
Mustang-junky
Mustang-junky
Post  nuclearcobra January 4th 2014, 7:50 pm
It is Zinc and found out its not worth the hassle, I'll just mill it down and leave it , or tap it and screw the tube in as someone suggested.
nuclearcobra
nuclearcobra
Post  cool40 January 4th 2014, 8:36 pm
I dont know what its made of but I had a1050 with one corner broke off. Somebody welded it back on and did a nice job.
Post  whatbumper January 4th 2014, 9:22 pm
I was thinking of the newer carbs with aluminum bodies that were plated. Sorry for the confusion on my part.
Post  nuclearcobra January 5th 2014, 9:02 am
The base plate is aluminum and can be welded no problem , the main bodies are made From Zinc ,they put a greenish chromic acid solution on it which forms a thin layer of zinc chromic coating on it as well to prevent corrosion , It said uncoated Zinc is a bright silvery metal that reacts with air and water to make a powdery material often called white rust. The new aluminum bodies would be no problem to fix.
nuclearcobra
nuclearcobra
Post  69F100 January 6th 2014, 7:59 am
nuclearcobra wrote:The base plate is aluminum and can be welded no problem , the main bodies are made From Zinc ,they put a greenish chromic acid solution on it which forms a thin layer of zinc chromic coating on it as well to prevent corrosion , It said uncoated Zinc is a bright silvery metal that reacts with air and water to make a powdery material often called white rust.  The new aluminum bodies would be no problem to fix.
You could try soldiering with silver soldier when I said it could be welded/tig I was thinking the body was aluminum
Post  nuclearcobra January 12th 2014, 11:44 am
I might try the JB weld thing or the tap idea, its only the vent tube , but still ticks me off , the carb was new and its a shame the post office beat it around like that and with Fragile clearly stamped on the box, Its the carb I bought from Wes and he was nice enough to offer my money back because he forgot to insure it , now that's a good guy right there Cool but I said no I want to keep it and fix it. https://2img.net/h/i195.photobucket.com/albums/z169/nuclearcobra/IMG_3460_zpsa0452ffd.jpg https://2img.net/h/i195.photobucket.com/albums/z169/nuclearcobra/IMG_3462_zpsc2ec014d.jpg
nuclearcobra
nuclearcobra
Post  the Coug January 14th 2014, 6:13 am
69F100 wrote:as long as you can get all the finish off and it is very very very clean where it needs welding unclean aluminum don't weld to good
I have his Proof
