P/W clearance SRP pistons
P/W clearance SRP pistons Empty P/W clearance SRP pistons
Post  Rmk Boss9 January 24th 2014, 1:09 pm
502 Scat stroker kit, will see maybe 6200-6300 rpm.
The paper work says .003-.0035. I will not be using any power adders
and its going in a 3700lbs. car and will street driven 95% of the time.
I may do a couple races a year. Apparently the 4032 pistons can run tighter
clearances than the other forged JE pistons.
Rmk Boss9
P/W clearance SRP pistons Empty Re: P/W clearance SRP pistons
Post  rmcomprandy January 24th 2014, 5:24 pm
Rmk Boss9 wrote:502 Scat stroker kit, will see maybe 6200-6300 rpm.
.0035" should be fine with 4032 alloy.
... and the hotter the water normally runs, the less the clearance can be. Cold water like in a marine situation needs more clearance.
