Head gaskets
J.Toney
69bluehotrod
Rmk Boss9
Head gaskets
Is there any special head gaskets you would use for aluminum heads?
This is 10.1 compression N/A 502, Edelbrock heads, around 500-525 hp.
Pistons are .005 in the hole.
Thanks Randy
Thanks Randy
Rmk Boss9- Posts : 19
Re: Head gaskets
I'd think the regular 1018 gasket would be more than adequate. Mine worked for 10.8:1 with TFS heads, studs, and a 150 shot.
J.Toney- Posts : 398
Re: Head gaskets
1018 ftw. @10.1 n/a
Re: Head gaskets
Did a little more research on this and that is the gasket Edelbrock recommends for their heads.
Thanks for the replies
Go Seahawks!!!!!!!!!!!!!!!!!!
Re: Head gaskets
The typical Felpro will be fine
jbozzelle- Posts : 3705
Re: Head gaskets
Contact Lem, ask him about the Ford Racing M-6051-A441 gaskets. Made by Felpro.
hienergy557- Posts : 179
» 429 head gaskets
» need head gaskets
» Max HP and Lift With SCJ Heads
» which head gaskets
» Head gaskets for 429 - which way go on?
» need head gaskets
