torque plate
+7
kim
Beast
dtimmer
LivermoreDave
460Dave
11 posters
torque plate Empty torque plate
Post  460Dave February 11th 2014, 10:36 am
It seems that machinists with a 460 torque plate is about as rare as hens teeth. How important is bore/hone with a torque plate on a block that was filled to the bottom of the water pump holes? (1/8"rings) The heads were on the block when the fill was drying.
460Dave
torque plate Empty Re: torque plate
Post  LivermoreDave February 11th 2014, 2:54 pm
IMO, a torque plate won't effect a filled block's (the level you mention) lower 1/2 of the cylinder as much as an unfilled block. Also IMO the cylinder's finish could be effected above the filled area where the rings dwell for longer periods of time. With that said, tops and bottoms of most cylinder's usually are more stable than the centers of the cylinder during the honing process considering temperatures are controlled. Of course if your block has been filled, the cylinders will need attention. I have experienced incorporating torque plates during the fill process. IMO this is a bonus. It is best to manipulate the block's integrity as an assembled part, not a separate piece.
Sorry about the paragraph,
Dave.
LivermoreDave
Post  dtimmer February 11th 2014, 7:25 pm
Story short. Use a torque plate.
dtimmer
http://www.visnerengine.com/
Post  Beast February 11th 2014, 9:13 pm
dtimmer wrote:Story short. Use a torque plate.
I've read quite a few times that using one is un-necessary on a BBF.
Beast
Beast
Post  kim February 11th 2014, 9:59 pm
Chevy guys will tell you all sorts of crap to try and mess up your engine.
A machine shop and or engine builder that's good with FORDS, can make chevies work miracles, machine shops, engine builders that excel at chevies, can fuck up a ford in a heart beat.
kim
Post  dfree383 February 11th 2014, 10:32 pm
It's not required in some peoples opinion, but it sure doesn't hurt to use one.
Post  supervel45 February 11th 2014, 11:11 pm
I hear they are only good for Chevy's since most machine shops don't have any for BBF's since they don't do many. Suspect Twisted Evil
Post  dfree383 February 12th 2014, 12:04 am
supervel45 wrote:I hear they are only good for Chevy's since most machine shops don't have any for BBF's since they don't do many. Suspect Twisted Evil
Chevys are different, the head bolts are smaller and more of them, the mounting points are shallow and not blind like a BBF. They are known to warp and distort the cylinders a lot worse than the BBF counterpart.
Post  supervel45 February 12th 2014, 12:13 am
I was just kidding around. BBF's are tougher for sure than BBC's but if you are building a high dollar race engine torque plate's are always a good idea, regardless, like you mentioned.
Post  hienergy557 February 12th 2014, 9:09 pm
kim wrote:Chevy guys will tell you all sorts of crap to try and mess up your engine.
That's funny, but true.
hienergy557
hienergy557
Post  Lem Evans February 12th 2014, 9:30 pm
X 2
Post  hienergy557 February 12th 2014, 9:46 pm
Where are you located? Maybe somebody on here that is close, has one you can use.
hienergy557
hienergy557
Post  fsc1982 February 23rd 2014, 5:54 pm
While I've never measured exactly how much a plate moves a cylinder in a BBF, I have plate-honed blocks that were originally honed w/o a plate by other builders. The amount of distortion at the head bolt locations is dramatic. They say seeing is believing, well you can certainly measure a tenth or three or five with a good bore guage, but it doesn't carry the same impact as seeing how much honing is required to clean up a cyl that was originally honed w/o a torque plate.
fsc1982
Post  Dave C. February 23rd 2014, 7:00 pm
Yep... Everything is made of rubber..... Everything moves.
Dave C.
Post  supervel45 February 24th 2014, 2:53 am
Thats just green blocks. Need a good rusted seasoned block, 44 years old, hard like an old O-Ring. Question
