Has anyone dynoed a similar combo?
+6
1EFF100
514Fox87
bbf468
10 posters
I was curious if anyone has dynoed this combo or something similar? 466 with flat tops, zero deck, ported dove heads flowing 325/180 ish, victor intake, 1050 Holley, comp 294b-8 cam. Roller rockers, race gas, comp ratio is close to 11-1.
I know that's not super specific.....
Kyle
Kyle
bbf468- Posts : 10
Re: Has anyone dynoed a similar combo?
Might be better to include cam spec's with your thread, because someone may have used one close, in case they do not want to look up the comp cam spec's or have them memerized, and you may get more response's.
supervel45- Posts : 4499
294/304, 256/266, .589/.614, 108 lobe separation
bbf468- Posts : 10
http://www.mustangsandmore.com/ubb/Archives/Archive-000006/HTML/20020913-12-000536.html This does not answer your question but your cam is mentioned, and the older cast heads also. I wish I could give you dyno results, but I can't. Your combo sounds pretty stout though.
bbf468 wrote:I was curious if anyone has dynoed this combo or something similar? 466 with flat tops, zero deck, ported dove heads flowing 325/180 ish, victor intake, 1050 Holley, comp 294b-8 cam. Roller rockers, race gas, comp ratio is close to 11-1.
Kyle
With a close combination with a solid flat tappet cam around the same size and a 4150 style, 950HP carburetor ... 580 lb/ft torque and 545 Horsepower
Thanks Randy, does the victor 4500 manifold need any attention at this point? Will a Holley 8082 be ok or should I look for a different carb?
Kyle
Kyle
bbf468- Posts : 10
bbf468 wrote:Thanks Randy, does the victor 4500 manifold need any attention at this point? Will a Holley 8082 be ok or should I look for a different carb?
Kyle
How is this to be used...? A #8896 can make a bit more power however, the part throttle fuel metering is terrible.
The manifold can be helped if you don't expect a big increase; it is pretty good as it is when the heads are "VICTOR" port matched.
No dyno numbers but my car ran 9.72 with a very similar combo. TRW flattops, A429 heads that flowed, 320/190 ported G429 intake, 1000cfm Prosystems carb. C-4 with 3.89 gears. Car was 2930 with me. Same cam degreed 2 advanced.
514Fox87- Posts : 436
Use will be 50/50 street strip. In a f100 approx 4000 lbs. Current cam is 238/248 @ .050 .560/.588 lift. Small headman headers and a 850 Holley with 8021 stealth. Heads have been worked on. Have the new cam and victor intake. Larger hooker headers are in the shop for it, current flow numbers are unknown. Ran a best of 12.80 with 3.50 gears, need to change them for some taller cogs.
Anyone ever try one of those dambest carbs?
Kyle
Kyle
bbf468- Posts : 10
Kyle, you and I would have been fender to fender in my old '79 F-100. My best was 12.82. 466, D1VE block, TRW forged big dish pistons, DOVE-A heads with exhaust bump removed, Torker II intake, solid Crane cam--246/256 @.050 .563/.583 lift 108 LS installed 2 or 4 degrees advanced, I don't recall now, 750 Holley pumper, junk small Flowtech headers, 4000 stall, 4.11 traction lock.
The thing came off the line like it was shot out of a cannon but nosed over kinda on top. I was shifting at 5200 and going through the lights, I think, at 5500 or 5800. It was a street/strip truck with full interior and exhaust. Fun as heck. Scared a few people when I took them for rides...
1EFF100- Posts : 265
Kyle
Heres one that a little larger engine with a dove head
http://www.460ford.com/forum/showthread.php?t=173210
BOSS 429- Posts : 2372
Karl's Flat top, DOVE heads, Victor and a dominator did about 630 hp with a big roller.
dfree383 wrote:Karl's Flat top, DOVE heads, Victor and a dominator did about 630 hp with a big roller.
This would of been there most likely , with a victor,1250,and a pair of headers
cool, post the build, I'm sure this guy would like to read about it,
what ci was it?
Here is my 460 I had in my Ranger by Wallace Calc said 538hp it is similar to what you are building
https://www.429-460.com/t18169-538hp-460-with-dove-heads-pics-added-no-longer-for-sale#213123
BOSS 429 wrote:dfree383 wrote:Karl's Flat top, DOVE heads, Victor and a dominator did about 630 hp with a big roller.
what ci was it?
It was a 472 it's listed under the builds here.
My brother ran a couple 466 combos as you described. 600 lift Flat Tappet camshafts, 3000 lb cars, both ran Mid 10's in the 1/4 in 2 different cars. Less than 600 HP?
Matt Jewell- Posts : 29
Running close to your build... 472ci, a429 heads, victor, 950, 258 258 615 615 sft cam, 3.89 gear, 480hp... runs 11.50 in a 52 F1 at 3870 with 600hp adding 125nitrous hit 10.54 @ 127
quick 52- Posts : 612
» P-51 headed 472 build... DYNOED
» Advise needed for my cheapskate 460
» Horsepower guesses
» my new combo
» Help with my combo.
» my new combo
