1970 Mustang AJE front suspension conversion.
+11
dirt_worker
NOS42
jeffgfg
512Fairlane
Matt Jewell
YellowStangDuane
5pointslow
Dave C.
70FB
15 posters
Page 4 of 6 Previous  1, 2, 3, 4, 5, 6  Next
1970 Mustang AJE front suspension conversion. - Page 4 Empty Re: 1970 Mustang AJE front suspension conversion.
Post  70FB February 24th 2014, 11:06 pm
Sorry for the crappy pictures. I worked on it last night until 12am last night then 12 hours at work today and we welded the major stuff tonight. Beer-thirty now.
70FB
70FB
Post  70FB March 7th 2014, 12:10 pm
Finished up the mounts, bars, lower radiator support, etc. Cleaned the edges up and threw a can of paint on it. Its to glossy so I'll go back with some semi flat black. I'll be assembling the front end this weekend and take some more pictures. The car will go to a guy Monday to get the two header tubes built, front end alignment and scale it....if I can get it all together this weekend.
1970 Mustang AJE front suspension conversion. - Page 4 0307140026_zps121ac291
70FB
70FB
Post  DILLIGASDAVE March 8th 2014, 12:26 am
Are you going to re-skin the tower & sides of the engine compartment, or leave it all open?
Post  jeffgfg March 8th 2014, 10:17 am
I was reading a magazine the other day and came across an ad that caught my eye and this thread came to mind. Fatman's fab has a complete bolt in kit to put struts under a 69-73 mustang and it also works on Torinos etc. It does away with the upper a arm and looks pretty slick. The other thing they have is a complete front end replacement for 65-68 mustangs. It replaces everything from the fire wall forward and is a strut front end. It accepts all engines and is really a nice piece. If I was building any of these models I would check them out!! Just wanted to let you know.
jeffgfg
Post  NOS42 March 8th 2014, 10:29 am
nice project! hope it turns out the way you want it
NOS42
NOS42
Post  70FB March 8th 2014, 11:19 am
DILLIGASDAVE wrote:Are you going to re-skin the tower & sides of the engine compartment, or leave it all open?
I'm going to leave it open. I hope I have enough bracing. The forward bars are welded to the outer side of the tower and the 1" tubes welded on the inside.
Future plans call for some A heads and complete custom headers. I'll probably end up adding extra tubes in then. One going diagonal from the top of the tower back to the bottom of the windshield/door bar. I still need to add a dash bar later so that would tie in to the midplate mount later like on the other thread.
70FB
70FB
Post  70FB March 8th 2014, 11:22 am
jeffgfg wrote:I was reading a magazine the other day and came across an ad that caught my eye and this thread came to mind. Fatman's fab has a complete bolt in kit to put struts under a 69-73 mustang and it also works on Torinos etc. It does away with the upper a arm and looks pretty slick. The other thing they have is a complete front end replacement for 65-68 mustangs. It replaces everything from the fire wall forward and is a strut front end. It accepts all engines and is really a nice piece. If I was building any of these models I would check them out!!  Just wanted to let you know.
I may be wrong but if I remember the Fatman deal was north of $5000. I may be thinking of the company that has the aluminum k member for these cars.
70FB
70FB
Post  70FB March 8th 2014, 11:23 am
NOS42 wrote:nice project! hope it turns out the way you want it
Biggest plus will be getting to the plugs now without having to use an open end wrench....and loosing 100-200 lbs.
70FB
70FB
Post  jeffgfg March 8th 2014, 4:59 pm
Yup the complete replacement front clip for the 65-68 mustang is almost 5800.00 However the bolt in strut suspension for the 65-73 starts at only 1995.00 and looks like a heck of a deal. Like I said I was just letting everyone know that there are other options out there.
jeffgfg
Post  richter69 March 8th 2014, 9:40 pm
your gonna need a brace like the factory ones that went from the tower to the top of the firewall and or one going from tower to tower....... it will flex I promise.
Post  70FB March 8th 2014, 9:57 pm
richter69 wrote:your gonna need a brace like the factory ones that went from the tower to the top of the firewall and or one going from tower to tower....... it will flex I promise.
I still have the factory one that goes to the firewall. I saw a picture of your brace that went from tower to tower. I may do something like that.
70FB
70FB
Post  richter69 March 9th 2014, 1:09 am
The factory brace may be enough, just measure with it on all fours and front wheels in the air, mine had over 3/8" of deflection hence the bar added across the towers
Post  70FB March 9th 2014, 9:23 am
richter69 wrote:The factory brace may be enough, just measure with it on all fours and front wheels in the air, mine had over 3/8" of deflection hence the bar added across the towers
Wow, with this setup that would change the alignment pretty good.
70FB
70FB
Post  70FB March 9th 2014, 10:58 am
Hey Dave, if I don't reskin it.... Will it have a negative effect? I do have the carb sealed to the cowl towards the windshield. If needed,I would make some carbon fiber inserts to seal it up.
70FB
70FB
Post  70FB March 9th 2014, 10:45 pm
I finally got one side finished up on the AJE setup. The caliper bracket for one side wouldn't fit on and had to take a hair out of it to fit on the spindle. Then the bolt holes wouldn't line up. I called AJE and they said 2 bolts would be fine to hold it. Those 2 bolt holes were a hair off also so I deburred them some to line up. These are a countersunk head to fit in so they had to be pretty close. Then I ran a tap through them. The back side gets a lock nut. Its definitely not a bolt in. I will be giving them all this info as the guy that had this kit before me returned it. Hopefully this will help them out in the future.
1970 Mustang AJE front suspension conversion. - Page 4 0309142231_zps0307566d
1970 Mustang AJE front suspension conversion. - Page 4 0309142232_zps9ebd89c2
70FB
70FB
Post  70FB March 10th 2014, 12:54 am
Installed the struts with no pressure on the springs and cranked it up by hand. Kmember is 4" from the ground with no motor. All 4 wheels on the ground now and rolls much easier compared to the old stuff. I'm  Very Happy  so far. Very Happy
1970 Mustang AJE front suspension conversion. - Page 4 0310140036_zps7497ecdc
70FB
70FB
Post  DILLIGASDAVE March 11th 2014, 1:44 am
If extra tube bracing isn't welded into the tower after the towers are trimmed back to help support the vehicle weight the tower caps have to carry (primary loading), then the open side really should be closed back up/re-skinned to help support the tower cap. One method or the other needs to be done when the towers are trimmed back (or both methods could be done together).
But adding back the missing sheetmetal won't really reduce the amount the towers might flex in/out (secondary loading). That's the reason for using the OEM (or tube) firewall braces and/or a cross brace like Jon mentioned.
Post  70FB March 15th 2014, 9:27 am
Engine plate and spacers finished up. I can start making my brackets to go from the forward bar to the engine plate now.
1970 Mustang AJE front suspension conversion. - Page 4 0314142339_zps886084eb
1970 Mustang AJE front suspension conversion. - Page 4 0314142343_zps2c8182e3
70FB
70FB
Post  70FB March 15th 2014, 9:30 am
Engine plate is sitting on the frame and has two bolts on each side through a piece of angle iron welded down. I'll make a bracket to attach the forward bar to the engine plate up where they intersect at to stiffen things up.
70FB
70FB
Post  richter69 March 21st 2014, 6:17 pm
Update
Post  70FB March 21st 2014, 11:01 pm
Rerouting everything that was on the inner fenders. Wiring,brake lines and solenoid. I still have to install the safety wire on the bolts that hold the rotor on. Flushing all the old brake fluid out and installing the shortened driveshaft. It ended up 1-3/8" back. Still have pinion angle and other stuff to do. I have just been working on the little irritating stuff lately while I have the engine out for the last time.
1970 Mustang AJE front suspension conversion. - Page 4 0318142125_zpsba16605e
1970 Mustang AJE front suspension conversion. - Page 4 0318142141_zpscffb5219
1970 Mustang AJE front suspension conversion. - Page 4 0318142150_zpsd4a85730
70FB
70FB
Post  70FB March 22nd 2014, 12:05 am
Finally took the cover off of her since December.
1970 Mustang AJE front suspension conversion. - Page 4 0321142358_zps882727be
1970 Mustang AJE front suspension conversion. - Page 4 0322140001_zps3e7436b3
70FB
70FB
Post  70FB March 30th 2014, 11:32 pm
Engine is in for the final time. I have 1-1/2 degree difference between the tailshaft and driveshaft going down. 2 degrees on the pinion angle. Oil pan is sitting 1/4" off the rack. Bellhousing is against the wall almost. I had to make a new trans crossmember. Fox body headers still fit except the 2 tubes. Rewired entire car front to back. Still have some wiring, bleed brakes,longer radiator hoses, install dash, front end alignment, upper engine plate mounts, etc.. still a ways to go but the worst of it is done.
1970 Mustang AJE front suspension conversion. - Page 4 0330142320a_zps088b1ad3
70FB
70FB
Jetman likes this post
Post  DILLIGASDAVE March 31st 2014, 3:35 am
Did you have to drill any holes in the firewall to make it easier to get to the bell housing bolts? Or was there enough room?
Post  70FB March 31st 2014, 7:23 am
I didn't have to drill any holes. I can get an open end wrench on the bellhousing bolts. One is a little hard to get started with the fingers.
70FB
70FB
