460 big block
460 big block Empty 460 big block
Post  beej February 22nd 2014, 5:18 pm
ok i got this 460 in a deal with a broken crank i was needing to know if it is externally or internally balanced the casting are d1ve 6015 a2b on the block and 2yabc on the crank. and im wantin to buy a new crank and harmonic balancer and im not sure wut to get..ive looked up the numbers but no one is giving a straight answer.....thanx
beej
460 big block Empty Re: 460 big block
Post  514Fox87 February 22nd 2014, 5:28 pm
That is a internal balance.  Another way to tell is, if it has a plain sleeve behind the balancer it is internal balance.  External will have a hatchet weight behind the balancer.
514Fox87
514Fox87
Post  beej February 22nd 2014, 5:31 pm
ok thanx alot i really appreciate it
beej
