My 598 TFS A-headed build
+16
butterbean
old blue
soupbean
bigjohn2007
460pulling
ProStreetFairlane
dirt_worker
61coon
Copperhead
20 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
This is a Jet-Boat Bob build
Ford A-460 block
4.60" bore x 4.50" Scat 4340 crank
Scat 6.80 Rods w/ ARP 2000 bolt upgrade
Diamond pistons 14.4 compression
Comp solid roller Camshaft
TFS A-460 heads w/ 2.35 intake valves, stock castings, Un-Ported
A-460 intake w/ very minor clean-up work
Wet sump w/ Kaase pump
Quick Fuel 1450
Renegade 112 fuel
The results are in,.....
Anyone care to make a guess on what it made?
Ford A-460 block
Quick Fuel 1450
Renegade 112 fuel
Copperhead- Posts : 492
61coon- Posts : 1824
Re: My 598 TFS A-headed build
PM me some cam numbers so I can get close.
If it is a Lemuel Evans cam, it made 995 @ 6900
IDT-572 wrote:If it is a Lemuel Evans cam, it made 995 @ 6900
LOL
Yep,......It's one that Lem spec'd out.
You better tighten up all your rear suspension bolts
Blake WILL be close. Nice build
Come on MAN! Don't keep us waiting!!!
windsor- Posts : 1167
Nice build Keith!
Any thoughts on why hp peaked at 6500?
I woulda expected it to peak around 7000.
dirt_worker- Posts : 535
I hadn't give it a lot of thought,..........BUT,... I'm actually glad it worked out like it did. This way I don't have to spin it to the moon to make the needed power. It'll be a lot easier on the valvetrain.
If I had to make a guess,.......the cam profile plays a major factor in it peaking where it did, as I told Lem when he spec'd it out, that I was planning on utilizing stock un-ported castings for the heads & intake.
That is almost scary!
Awesome numbers sir. Stock heads, nice!!!
I'm guessing it wants more airflow...
I excited to hear how it runs!
ProStreetFairlane- Posts : 34
Awesome
Very nice build and numbers with un-ported heads. Jetboat does some nice work for sure.
460pulling- Posts : 249
991.2 hp @ 6,300
991.9 hp @ 6,900
There is realy not a pronounced 'peak'.....looks flat to me.
991.9 hp @ 6,900
What kind of converter/stall you going to put in there?
windsor wrote:What kind of converter/stall you going to put in there?
I'm going to try to utilize my Ultimate Converter Concept 9" unit that I used on my previous 557 engine. I might have to have it adjusted to suit this set-up, but I want to try it first and get a baseline before I send it in.
Heck,.....If I'm lucky it might be good to go. Time will tell.
Lem Evans wrote:so, where did it stall?
It's been 2+ years since I ran the truck, BUT,.... "IF" I remember right,...
It would flash to around 5500 on the T-Brake.
Cool...hope the conv works out nicely.
Would love to see lower rpm torque numbers.
Very nice!! Unported heads too. Are they 18 bolt heads?
68formalGT- Posts : 865
So are these the same heads you had on the old 557 that Seth originally built?
Ah. Yes, recall now that was sold a second time. Thanks, Lem.
» 572 P-51 headed build...
» My 598 TFS A-headed build 2.0
» 572 A-460 headed build
» sr-71 headed 545 build
» Here's my SCJ headed 521 build...
Page 1 of 3
