Here's my SCJ headed 521 build...
Here's my SCJ headed 521 build... Empty Here's my SCJ headed 521 build...
Post  ThndrChkn August 17th 2009, 11:51 pm
D0VE-A 4-bolt main SCJ block bored and honed to 4.397
4.300" Scat Forged crank...
Main clearances are .0027 and rod clearances are .0023
6.800" Eagle H-Beam rods...
Kaase rear sump pump...
Probe flat top pistons...
Total Seal file fit rings gapped to .028 Top, .032 2nd, and std. tension oil ring...
FRPP SCJ heads ported/flowed by someone in Michigan to 385/254... Decked to 71cc for 14.2 C/R... (according to Diamond's website calculator)
Fel-Pro 1018 Head Gaskets...
Springs unknown, but 308# seat & 805# open, with Titanium retainers and lash caps... Std. 2.20/1.76 valves...
FRPP timing set...
Solid Roller spec'd by Tom Magyar at Ford Performance .280/.288 @ .050 & 786/726 lift @ 113 lobe sep... Installed 3.5* adv... Piston/Valve clearance is "tight" (Huh Blake...? Shocked ) Ground & dbl. pinned through Scott @ RHP
Scorpion 1.73 Roller rockers...
Untouched 4500 Victor intake w/ 2" open spacer... Quick Fuel QFX 1250
No dyno #'s, but my truck weighs 3220# with me in it, and has a best ET of 6.17 @ 112 mph 1/8, and 9.73 @ 136 mph 1/4 (@ 1200') and 6.34 @ 112 mph 1/8 @ 5000' and 9.97 @ 136 mph 1/4 @ 5000' through a Glide and 4.88 gears on TOYO 32x14x15 tires...
It ain't the fastest, but it's gettin' there & it sure is fun to drive... Very Happy Very Happy Very Happy
Doug... Cool
ThndrChkn
ThndrChkn
Here's my SCJ headed 521 build... Empty Re: Here's my SCJ headed 521 build...
Post  bruno August 19th 2009, 1:01 pm
nice build Doug Very Happy
http://WWW.CKRME.COM
Post  res0rli9 August 19th 2009, 3:00 pm
good build Doug. wallace cal. saids hp from mph is 552 for 1/8 and 565 1/4.
Post  NO FAIR August 20th 2009, 10:43 am
Very respectable times Doug.
According to Wallace calculators if you were at sea level the correction factor shows you at 9.81 ET
Dave
cheers
NO FAIR
NO FAIR
Post  ThndrChkn August 20th 2009, 3:25 pm
Thanks Dave... I'm sure it has a bit more in it if I can get my 60's down a little more... Very Happy scratch
Doug... Cool
ThndrChkn
ThndrChkn
