Water tank in trunk.
+14
simpleman
cheatham
JohnSwenson
David Willingham
Jeff Chandler
LivermoreDave
Northwest outlaw
18 posters
Water tank in trunk. - Page 2 Empty Re: Water tank in trunk.
Post  richter69 November 8th 2009, 10:52 am
the Coug wrote:the way I look at it is if you have to stick it in the trunk, then it is time to either put it on a diet or if you are doing it for weight then put some dang tires under it so you can stick it..... Surprised
JMHO
Car sticks fine now. Besides I priced a glass front clip, 1000 bucks to my door, I'll build a lighter "cooling system" than you. Besides I dont need all that bulky ass radiator and fan, the wonders of alky................ bounce
Post  bruno November 8th 2009, 12:18 pm
thxs for the link jeff Wink
http://WWW.CKRME.COM
Post  richter69 November 9th 2009, 11:44 pm
Man this 20 gal per minute pump on 16v is a monster.
Decided to not do the trunk tank, gonna do the 2 quart deal up front for now. If it does give me fits with heat this summer I am going to put soome fittings on the tank so i can put a tranny cooler in line and put it under the trunk with a fan like I did the actual tranny cooler.
Took an old alum oxygen cyl and cut the flat bottom off, tapped the hole where the valve was and put a 90* 12an fitting there to feed the pump. I experimented with outlet positions in the tank, and after a few hours came up with a solution that wouldn't blow water everywhere, aerate, or cause such a whirpool in the tank the pickup actually sucked air.
Try and get some pics of everything as i finalize it and before i weld it all up. Gonna use a reg rag cap bung on top, and run the vent line into the trunk where the overflow can is.
I'm even considering using the Evans coolant this go round, just to keep the possibility of hot spots out of the heads.
Its winter, and I'm bored lol. Did manage to get the smallblock in the 81 and hang the headers for mock up.
Post  simpleman November 10th 2009, 12:06 pm
richter69 wrote:I'd at least run water through the block and heads, the heads will get hot spots in them.
Will the cylinder walls have any chance to get the same type hot spots?
What about some other fluid than water? Would heat alone move the fluid/water if a small expansion tank was mounted higher than the intake & heads.
We raced for 2 seasons with a dry block in a mud drag truck on gas. No adverse affects that I know.
simpleman
simpleman
Post  richter69 November 13th 2009, 11:34 pm
Water tank in trunk. - Page 2 TV10-17-09001
My 20 dollar expansion tank............should get the rest plumbed tomorrow and start on the vac pump...... Very Happy
Post  billandlori November 14th 2009, 12:38 am
Thats lookin great!! Nice welds. That sure is gonna save a bunch of lbs over the rad etc.
Do you have any weights of the rad, water, hoses, etc vs the new set up?
Bill
Post  bruno November 14th 2009, 8:52 am
send me one too jon .....looks good
Post  richter69 November 14th 2009, 10:11 am
Its gonna net a 25# loss, dont sound like much, but it also unclutters the front of the eng bay.
Like I say this may not prove to be enough cooling in the summer, so I left provisions to plumb hoses into the system and i'll run a set of -6 lines to the rear of the car and use a tranny cooler with a fan. The pump has enough volume to pull it through the cooler as well.
Post  billandlori November 14th 2009, 10:57 am
25# can be hard to come by. I'm not going to say anything about 1/2 lb cheese burgers.....oops!! Laughing Shocked
Cleaning up the engine bay is a good thing too!!
Bill
Post  jbozzelle November 14th 2009, 1:27 pm
Jon, what pump are you using?
Post  richter69 November 14th 2009, 1:50 pm
Its a Meziere 20 gpm remote pump, same on thats been on it.
Post  jbozzelle November 14th 2009, 2:00 pm
Thanks. I need a remote one myself.
Post  richter69 November 14th 2009, 4:30 pm
everyone says you need the bigger pump, IMO the 55 gpm is way too much, I never had cooling issues with this one even on gas.
Post  Frank Merkl November 14th 2009, 8:48 pm
NHRA rules state that ,1.1 All cooling systems/radiators must be installed in the stock location for the body style used
fRANK
Post  richter69 November 14th 2009, 8:52 pm
Yep big debate in that thread on the bullet................I see lotsa fast cars with um back there ............racing.
Only time I ever saw NHRA tech serious is a divisional...............none of these guys run them lol.
There is a lot of grey area there anyway.
Post  Frank Merkl November 14th 2009, 8:59 pm
I'm the Head tech at our track , and if it don't meet the rulebook it don't run !!
Post  richter69 November 14th 2009, 9:04 pm
Tech at the 1/8th mile track here is I fill out the card and brother runs it up to the tower............
I doubt any of these guys that are set up this way will make it up there for a race so I wouldn't sweat it.
Besides when was that rule written? ...............food for thought.
Post  Northwest outlaw November 14th 2009, 10:33 pm
yea im good to go my car did have a rad.. Water tank in trunk. - Page 2 Icon_twisted
Northwest outlaw
Northwest outlaw
Post  DILLIGASDAVE November 15th 2009, 8:16 am
I don't know if this was mentioned in the YB thread (too damn long to read) but with a water tank in the trunk you will be adding some of the weight loss right back into the car from the 20' or so feet of water line to & from the trunk & the water weight in said lines.
Post  richter69 November 15th 2009, 12:14 pm
yeah I know, thats the reason I axed the tank idea. Got the tank all plumbed and running, lost 25 #'s, system holds 2.75 gallons total. What weight I did put back with the tank is all on the motorplate vs being hung out in the nose.
Post  Greg_P November 15th 2009, 12:26 pm
Frank Merkl wrote:I'm the Head tech at our track , and if it don't meet the rulebook it don't run !!
Awesome! It must take, what, a week to tech in 100 cars?
Racing in Canada must be AWESOME!
Laughing
Greg_P
Greg_P
Post  richter69 November 21st 2009, 4:40 pm
Water tank in trunk. - Page 2 TV10-17-09003
Water tank in trunk. - Page 2 TV10-17-09004
Post  billandlori November 21st 2009, 6:14 pm
Is that ever a slick looking set-up Jon. Nice clean intall.
Not sure what the driver's side looks like, its cut off Evil or Very Mad
Alky sure is nice to run!!
Bill
Post  racnrick November 22nd 2009, 2:29 pm
richter69 wrote:Water tank in trunk. - Page 2 TV10-17-09003
Jon,
Looks good. Where did you find that Y with AN fittings?
racnrick
Post  richter69 November 22nd 2009, 2:50 pm
Jegs, its a "Jeg" part, flipped it over so you couldn't see it lol.
