My midplate troubles.
+16
kim
5pointslow
70FB
CDMBill
DFI429
Wheelie58
DanH
yellowhorse7
BigRigTech
20 posters
Page 1 of 3 1, 2, 3  Next
My midplate troubles. Empty My midplate troubles.
Post  BigRigTech March 5th 2014, 4:50 pm
I bought a KFM mid-plate for my fox body but it's not going to work as is. I'm not sure what to do, the mid-plate would almost be into the firewall with the engine in it's current spot. Not only that but my super comp's would take out most of the mid-plate where it would mount. It would need more meat on top for the bolt tabs. Maybe I should fab some solid engine mounts to go along with the front plate? Right now I just have the front plate and a tranny mount holding the deal in place.
My midplate troubles. 003_zps3ec13423
My midplate troubles. 002_zpsc3eea0c6
My midplate troubles. 005_zps43c549da
My midplate troubles. 006_zpscadd5bdd
Here is the plate I bought and the cardboard template of what is left after I would clearance it around the headers.
My midplate troubles. 021_zps3134bd12
My midplate troubles. 011_zpsa441f708
My midplate troubles. 013_zps8cce59a9
BigRigTech
BigRigTech
My midplate troubles. Empty Re: My midplate troubles.
Post  the Coug March 5th 2014, 4:55 pm
sorry I spoke to soon
Post  BigRigTech March 5th 2014, 5:05 pm
I've been advised not to run my tranny without something attaching it to the car other than the bellhousing bolts, even a stock rubber mount better than nothing is what was said to me. Busted trans case trying to leave the car under motion is the reason I was given. It's happened here already and from what I was told it wasn't pretty. I just wanted to spread the load around a little that's why I bought the mid plate.
BigRigTech
BigRigTech
Post  the Coug March 5th 2014, 5:17 pm
Post  richter69 March 5th 2014, 5:37 pm
No need for a trans mount, it does not need it w a front and a mid plate.
Honestly if you cant make the mid work loose the plates alltogether and run solid eng mounts and a rubber trans.....
Lots of fast cars run no trans mount w plates.... The tranny wont fall out and if the tranny cails that bad a little rubber aint holdin it place.
Post  richter69 March 5th 2014, 5:41 pm
The three mounts will assure you a busted case if the transmount is solid. If ya gotta go find the most wore out transmount you can find and leave it loose.....
Post  BigRigTech March 5th 2014, 5:52 pm
The mid plate would be a nightmare as far as I can see, the engine is so far back it would be a PITA. I ran a front plate and a rubber mount last year but the drivers side bolts in the water pump kept backing off a bit and the car had a cold water leak on that side all summer once it cooled down. This is why I wanted to beef things up a bit. As for solid mounts, the brackets on the AJE tubular k-member aren't that rugged looking to me and I'd have more trust in the front plate to be honest. I have front to back limiters now that bolt to the k-member engine brackets and the engine mount holes in the block. I think I'll just go with what I was already, I just need a new tranny mount as I'm switching from a long tailshaft Lincoln C6 to a truck version with the short tailshaft to save 10lbs. I have a stock double hump tranny x-member in the car, a truck mount is too tall and fudges my driveline angle so I'll likely build a new tranny cross-member unless I can find a mount that is shorter in height. I was looking at some on rock auto today that might work.
BigRigTech
BigRigTech
Post  yellowhorse7 March 5th 2014, 5:55 pm
Never mind...... Rolling Eyes
yellowhorse7
yellowhorse7
Post  the Coug March 5th 2014, 6:08 pm
I am sorry I just said what my Chassis builder said but what does he know he only does it for a living he should just come and ask these guys.. so I apologize for steering you wrong..
Post  BigRigTech March 5th 2014, 6:43 pm
the Coug wrote:I am sorry I just said what my Chassis builder said but what does he know he only does it for a living he should just come and ask these guys.. so I apologize for steering you wrong..
I'm confused - I didn't disagree with what you said - I just passed along what I was told - right or wrong. Is there a thread on here that doesn't turn into a pissing match????  Rolling Eyes
BigRigTech
BigRigTech
Post  yellowhorse7 March 5th 2014, 6:56 pm
Which is why I deleted my post. Carry on Sir
yellowhorse7
yellowhorse7
Post  DanH March 5th 2014, 7:01 pm
like politics and religion-building a car has many beliefs on what should be done and how to do it.
Oh no, a ban on auto talk coming here? LOL
DanH
Post  Wheelie58 March 5th 2014, 7:11 pm
I hope that I didn't miss out on something...
I have no problem making a custom plate with more material where you need it.
Just give me a call and we can discuss getting that plate back here and a new custom one as needed.
Thanks,
Keith
678-458-2033
Wheelie58
Wheelie58
Post  richter69 March 5th 2014, 7:13 pm
all them fast ass MDRC cars aint gotma tranny mount, nor do the top 5 or so on the Street Outlaws list lol.
If the factory mounts are a no go then the front plate and a trsnsmount is fine, I know of atleast one car this way.
rear exit headers and a midplate on a fox dont mix...... unless you mount the midplate from the top also but tthats a good bit of fabwork to make it happen.
Post  BigRigTech March 5th 2014, 7:24 pm
Keith - if I don't bother with the mid plate I'm going to keep it anyways, it would be handy for a run stand. It would be so close the fire wall I'm not sure how to make it work. I put my engine and trans in as a unit and this is where I think a mid plate could be more of a hassle then it's worth. I just put an old block and tranny in the car this afternoon so I'll have a fresh gawk at it tomorrow.
BigRigTech
BigRigTech
Post  Wheelie58 March 5th 2014, 7:26 pm
Ok
Just let me know if I can help.
Thank you,
Keith
Wheelie58
Wheelie58
Post  yellowhorse7 March 5th 2014, 7:27 pm
richter69 wrote:all them fast ass MDRC cars aint gotma tranny mount, nor do the top 5 or so on the Street Outlaws list lol.
Fact is both have been done and obviously work. You do it your way, I'll do it mine. And I GUARANTEE my way won't crack a case.
yellowhorse7
yellowhorse7
Post  BigRigTech March 5th 2014, 7:32 pm
Wheelie58 wrote:Ok
Thank you,
Keith
Will do - thanks, Yellowhorse - what is your way???
BigRigTech
BigRigTech
Post  richter69 March 5th 2014, 7:35 pm
lets go on FB and cry about it lol.
Post  yellowhorse7 March 5th 2014, 7:36 pm
Mickey (your local guy) uses them too...
My midplate troubles. 100_56461
yellowhorse7
yellowhorse7
Post  yellowhorse7 March 5th 2014, 7:37 pm
richter69 wrote:lets go on FB and cry about it lol.
I did lol. Actually, it was something else that set me off but this was the proverbial straw. Love ya Jon
yellowhorse7
yellowhorse7
Post  richter69 March 5th 2014, 7:37 pm
that aint a tranny mount lol..... lateral limiter, set up just like mine and all the MDRC cars.
Post  yellowhorse7 March 5th 2014, 7:40 pm
BigRigTech wrote:
Wheelie58 wrote:Ok
Thank you,
Keith
Use one.....Poly, Rubber, Solid....don't matter. The PS guys use sliders so that the bottom of the trans is supported but has the ability to move if need be. But PS cars, with their tube chassis, are much more rigid and prone to cracking stuff (like Jon was describing) with the power they make.
yellowhorse7
yellowhorse7
Post  yellowhorse7 March 5th 2014, 7:41 pm
richter69 wrote:that aint a tranny mount lol..... lateral limiter, set up just like mine and all the MDRC cars.
Yes, but it still holds the trans in place so to say. Maybe I am using the word "mount" differently.
yellowhorse7
yellowhorse7
Post  richter69 March 5th 2014, 7:49 pm
my sb car
My midplate troubles. TV10-17-09003-17
My midplate troubles. TV10-17-09-3
bb car old pic
My midplate troubles. DSCF0903
granted the midplates are not just stuck in there there are an integral part of the chassis
