Who around il. ind. Ky. tristate can hone a cam tunnel?
460pulling
kim
ED468
Was wondering about Mike Philops in KY. The second whole has some damage on my Boss 302 block, like to beable to install the front bearing in the second spot since it .015 bigger o.d. , what two cam bearing kits lol, dont want rollers on the street.Thanks
ED468- Posts : 200
Re: Who around il. ind. Ky. tristate can hone a cam tunnel?
why not, you can pin prick the roller shell and feed oil spray and viola.... low resistance, and oil cool....
kim- Posts : 700
been some descussion on that.
But dont want to run a billet cam, hydr. roller would keep cost down alot also.
ED468- Posts : 200
ED468 wrote:Was wondering about Mike Philops in KY. The second whole has some damage on my Boss 302 block, like to beable to install the front bearing in the second spot since it .015 bigger o.d. , what two cam bearing kits lol, dont want rollers on the street.Thanks
Mike cannot do it at Philpot. Go to Mark Cummins in Princeton, IN. They are known for building sprint car engines, but they can do it.
Charlie
c.evans- BBF VENDOR SPONSOR
Bob Hardison
Jet boat Bob can in Island Kentucky. He has a very nice shop also.
Bob Hardison
265 Meadowview Drive
Island, KY 42350
270-486-9060
Bob Hardison
Island, KY 42350
270-486-9060
460pulling- Posts : 249
Oakley may be able to do something with it too. He's right up the street from Mike Phillips.
I don't know where you are located, but Tony Bischoff, can do it , he is in the Cincinnati area.
342g- BBF CONTRIBUTOR
cam tunnel
Thanks guys didn't know so few shops did it, I seen clevite sells .010 oversize bearings is this o.d.?
ED468- Posts : 200
Bishoff is good. There's also another local engine builder (in northern ky) by the name of Jim nave that could more than likely do it. He's built a lot of circle track small blocks screamers and offroad engines that I know of. I could get his contact info for you if it would be convenient.
Jeremy
Jeremy
Foxfire85- Posts : 35
Let your fingers do the walking and call around. A shop with a 2 1/4" arbour for their line hone could possibly do it.
However, it will be best to bore it to within a .001" of the finished size.
I send mine out to 2 different places ... one to bore it and one to finish hone it.
If there is NOT something special about that block, then get another.
EDIT: I missed that it was a small block. The line hone arbour won't work as the holes are all different sizes. I thought this was for a big block.
Have them all bored to the same size and use the DART block cam bearings.
rmcomprandy wrote:Let your fingers do the walking and call around. A shop with a 2 1/4" arbour for their line hone could possibly do it.
Thats what i would do
![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
» 545 Stroker Kit Line Hone
» flex hone to deglaze cylinder
» Is there a need for a short timing set after a align hone on mains?
» Blue Thunder tunnel ram info?
» motorsport a-460 heads other parts added
