Offenhauser tunnel ram fit dove heads? Gasket?
Will an offenhauser tunnel ram fit unported dove heads? I dont have any numbers from intake. Does this intake have cj size ports?
If so what gasket do i need to get?
Thanks for any help.
77ford- Posts : 26
Re: Offenhauser tunnel ram fit dove heads? Gasket?
The Offy TR has CJ size ports. Can run it on a stock D0VE head, just be a port mismatch which I would NOT worry about. You will need to use a CJ intake gasket for it to seal. Mr. Gasket PN: 208A or 5839 will work as will any other CJ intake gasket.
466cj- Posts : 391
» Offenhauser tunnel ram
» Dove-c Heads
» A429 Heads VS Dove-c Heads
» D3V3 A2A Heads, Which intake gasket?
» Dove-c Heads
