Burning Alcohol
+6
Wheelie58
powerstrokeace
BigSmut79
10 posters
Page 2 of 2 Previous  1, 2
Burning Alcohol - Page 2 Empty Re: Burning Alcohol
Post  Curt March 31st 2014, 7:30 pm
Once you have the ability to run a hat, you can run the Ron's primer. You just sandwich in between like you would a nitrous plate.
Post  BigSmut79 March 31st 2014, 7:38 pm
Another question, the guys up there were discussing prices of fuel, what does a 55 gallon drum of C12 go for?
BigSmut79
Post  cool40 March 31st 2014, 9:58 pm
All you need for an adapter is a piece of aluminum plate.if your intake has a dual carb top use it to lay out the holes on the plate.
Post  69F100 April 1st 2014, 12:18 am
5pointslow wrote:no to get off topic
but M1 locally to me is 7.50 a gallon if you burn 2-3 gallons in the driving to lanes , burnout ,run and return .
isnt this being in the same boat or close to racing gas ?
most big single carbs on 500 plus ci engine id assume would still use 1-1.5 gallons per the same proccess as above ?
seems it would come down to preference i maybe wrong , plus the maint of alky . If you go on killer rons they swear its cut and dry andf maint isnt that bad .
We / Rick and me went together last time and bought 2 drums  I think it was $165 a drum if we bought 2 or $190 for 1 drum. It will last a long time as long as you keep it shut up good so no moister can get in it. Not sure on the c12 never priced it around here.
