Ring filers
AZFairlane
Ring filers Empty Ring filers
Post  AZFairlane May 29th 2014, 9:31 pm
Is there any difference between the manual and electric ring filers? Does one give a better surface than the other? Is the electric one just for shops that do a lot of file fit rings and the manual model is fine for the "hobbyists". Thanks.
AZFairlane
AZFairlane
Ring filers Empty Re: Ring filers
Post  rmcomprandy May 29th 2014, 11:24 pm
I have a BHJ electric grinder and I still use a "new" $5.00 mill file clamped in a vice for gapping rings. It's faster and easier however, you'll probably need tough fingertips.
These days, I use the electric one for filing one end of rear main seals, LOL.
(It has an indicator so, I know exactly how much I shorten it).
Post  zbob May 30th 2014, 9:30 am
joe due to lack of experience I like the manual ones. I still managed to wreck a couple of rings on the way learning. It was easier for me to sneak up on the correct gap and to make sure the end was square.
..... get a diamond knife hone to remove the tiny burr too. AND get a solid ring compresser not the pos we used back when. goes a long way to prevent scores in the cylinder and broken rings,,,,,bob
zbob
Post  bbf-falcon May 31st 2014, 10:02 pm
zbob wrote:joe due to lack of experience I like the manual ones. I still managed to wreck a couple of rings on the way learning. It was easier for me to sneak up on the correct gap and to make sure the end was square.
Me too bob. Wink
Post  whatbumper May 31st 2014, 11:15 pm
We do it by hand as well. Doesn't take very long and yes, get a solid ring compressor like mentioned above.
Post  AZFairlane May 31st 2014, 11:53 pm
Will do guys, thanks a lot.
AZFairlane
AZFairlane
Post  69F100 June 1st 2014, 9:59 am
I use a manual one also it belongs to Rick aka 557mazda take me a little bit to get my rings to fit cut a little off check take a little more off recheck until I get the gap I need
