Seal protector
Re: Seal protector
HorsinAround wrote:Is a seal protector necessary to install the pistons in a C6? where can I get one?
No seal protector needed ! Just use a feeler gauge to help with the lip seal on the forward clutch the rest should be square cut seals.
whitefield- Posts : 2244
Re: Seal protector
these seal kits I been getting lately come with a round plastic disc thats pretty flexible..... that thing works awesome.
as stated the forward has a lip seal and can be tricky sometimes....
Re: Seal protector
I just smear the seals with a lil grease, and install them with care, no special tools needed
DeepRoots- Posts : 110
Re: Seal protector
I've not used those plastic discs but they have come in the last few kits. I have a tool I made up, is a fierce of 1/4" tube , the end flattened to retain a loop of mig welder wire. You can buy a tool same. Works well for working around the lip type seal in later C6 forward drums.
Gregaust- Posts : 625
Re: Seal protector
Thanks for the replies. I got my kit from Broader so I'll check to see if it came with the plastic piece. If not I'll try a little grease and feeler gauge.
» Cleaning off light rust from a crankshaft - how too?
» Boss cranksnout conversion
» Axle bearing seal ?
» Morning funny....
» C6 shifter seal
» Morning funny....
» C6 shifter seal
