should head gaskets be retorked?
should head gaskets be retorked? Empty should head gaskets be retorked?
Post  Larry T June 26th 2014, 8:31 pm
i have a few passes on it now and was wondering if I should?block is O ringed .060 copper gasket with 7.3 gasket sealer torked @140lbs.if so im not looking forward to it.........
Larry T
Larry T
should head gaskets be retorked? Empty Re: should head gaskets be retorked?
Post  rmcomprandy June 27th 2014, 12:08 am
Larry T wrote:i have a few passes on it now and was wondering if I should?block is O ringed .060 copper gasket with 7.3 gasket sealer torked @140lbs.if so im not looking forward to it.........
Manufacturers say it is not necessary but, head gaskets will seal better and last longer if they are re-torqued ... one fastener at a time following in the normal torque sequence. Back each fastener off 1/4 turn and re-torque it to whatever it is supposed to be ... One fastener at a time in order.
Post  cool40 June 27th 2014, 12:15 am
Do your heads have a receiver groove? If not you'll be damn lucky it dont leak.
Post  Larry T June 27th 2014, 8:38 am
yes,reciever grooves on board and in the correct place this time lol..............
Larry T
Larry T
Post  dfree383 June 27th 2014, 9:39 am
Good idea on most applications..... Required on some.
