Shortening a MSD Distributor
+10
Dave C.
bronco911
14 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Ok, have clearance issues and don't want to go with a crank trigger. Where does it say I can't just cut my MSD down 1-1/2"?
Nothing comes up with google, good or bad. Have it torn down, looks pretty simple. (Have the lathe and required machines)
Anybody have any thoughts on this?
Thanks, Ray
Thanks, Ray
bronco911- Posts : 103
Re: Shortening a MSD Distributor
What part number are you running?
Can you use a factory small cap duraspark unit? And just add a msd connector to it?
8578 is as short as it gets.......351w unit....would have to change gear to 460 style.
Charlie has done some 'bastard' deals using a duraspark with a crab cap.
I almost have it done, I will post results. Dave, yes I can go the dura spark route, but I just think this is almost as easy, with no added expense but time (as long as it works)
Use a totally rebuilt FORD DURASPARK distributor for a 351M/400 Ford engine. It is the shortest one made for the 335/385 series engines.
David, Lem and Randy. Is there any reason to NOT just cut the MSD down? I know the dura spark route, but I was just wondering why nobody does it. Looks really good, and still keeps the "performance" dist. Once I figure out picture loading I will post pics of the process.
I know the duraspark will work...... And it won't be expensive, bronze gear, connector, parts store dist and good cap..... Under 175ish dollars.
Cutting it..... We'll it seems bad to take a chance at destroying something that will probably pay for the alternative duraspark that we know will work.
I have durasparks in several performance engines they work great. Msd stuff was modeled of them. In fact I have an original msd / Motorsport distributor that is a duraspark in one engine.
I don't see a problem with cutting off an msd distributor.not much lost if it dont work out! Lol
bronco911 wrote:David, Lem and Randy. Is there any reason to NOT just cut the MSD down? I know the dura spark route, but I was just wondering why nobody does it. Looks really good, and still keeps the "performance" dist. Once I figure out picture loading I will post pics of the process.
What shaft do you intend to use...?
Can you EDM the hex in the bottom of the shaft or do you intend to section and reweld that...? Perfectly straight.
There is not enough metal in an MSD housing upright to machine the diameter of the flange so, that housing will need to be cut and rewelded, also.
Have at it, if you want a project which is doomed to fail somewhere along the line.
If you want an MSD so bad, it would be a lot easier to get one for a WINDSOR and change the gear.
You do know that the MSD magnetic impulse generator IS a Ford Duraspark unit, right...?
rmcomprandy wrote:bronco911 wrote:David, Lem and Randy. Is there any reason to NOT just cut the MSD down? I know the dura spark route, but I was just wondering why nobody does it. Looks really good, and still keeps the "performance" dist. Once I figure out picture loading I will post pics of the process.
Used the same shaft, cut the top off with a carbide hole bit and then cut 1-3/4 off that end, slipped it back on the cut shaft and rewelded on the top, same as original. The housing only has a 3/4 bushing machined in at the top of the straight housing, so you have over 4" of solid straight billet that can be shortened, which I did. Sectioned it and made it into a slip fitting, with a relief for the exterior weld where they meet. Welded it and put her back into the lathe and turned the weld, looks like brand new, never touched.
Works perfect, looks great. Took 3 hours, not a penny spent, and was able to finish my project on a Sunday
The Windsor MSD only gains you 5/8" which was not enough. Had to have 1-3/4
Yes, I know the MSD mig is based off a dura spark, as stated previously.
So, my take from this is the answer is nobody has tried it till now, because they are worried about an oops costing to much money and most don't mind spending hundreds on all the pretty fittings and billet brackets and then throwing an antique looking distributor on that high dollar motor. Gotcha
Good deal, now lets see some pic's .
res0rli9- BBF CONTRIBUTOR
My kinda guy............. Good job, now lets see some pics ! ! ! ! ! ! ! !
Good Job but, I am curious.
IF you already knew then why the hell did you ask...?
rmcomprandy wrote:Good Job but, I am curious.
The original question was prior to dissecting the MSD, and it was wondering if I was missing something technical that prohibited it from being done.
That's all I was asking, not for what everyone knows will work, but what was I missing that nobody had done it. Figured the great minds around this place would know
Just to irritate you......
richter69 wrote:Just to irritate you......
Yes, getting the vibe I may have touched a nerve
bronco911 wrote:richter69 wrote:Just to irritate you......
Custom work such as you are doing is the norm out here in the birth of drag racing. The guys I work with have been making their own custom/modified distributor bases for decades. Also, the base used specifically for our Offset Mag Drives is just 3 inches in length and sticks out atop the block by only 1.6 inches.bronco911 wrote: The housing only has a 3/4 bushing machined in at the top of the straight housing, so you have over 4" of solid straight billet that can be shortened, which I did. Sectioned it and made it into a slip fitting, with a relief for the exterior weld where they meet. Welded it and put her back into the lathe and turned the weld, looks like brand new, never touched.
So, my take from this is the answer is nobody has tried it till now...
The reason the 385 Series housing supports the distributor drive shaft with only the single bushing at the top is because the lower end of the drive shaft is supported by the receiver-bore in the block's distributor thrust boss.
I don't what is with all the flack. You need something custom so you made it. The car world is full of engineers, machinists and welders that make stuff all the time. No big deal IMO.
I just want to know where are the pictures??
jasonf- BBF CONTRIBUTOR
jasonf wrote:I don't what is with all the flack. You need something custom so you made it. The car world is full of engineers, machinists and welders that make stuff all the time. No big deal IMO.
Hey now, don't forget us lowly carpenters!!!
I have a ton of pics, but for some reason my Ipad air does not like to share. If anyone can tell me the trick they will be visible ASAP
Up load them to photo bucket and copy paste into your post.
Let me know if this works
https://s1284.photobucket.com/user/bronco9111/library/
Page 1 of 2 • 1, 2
» Shortening a Scat Crank
» MSD Distributor to replace Duraspark Distributor?
» stock distributor vs msd distributor
» WTB Distributor
» Distributor
» WTB Distributor
» Distributor
Page 1 of 2
