Shortening a Scat Crank
Can a forged Scat 4.5" crank snout be shortened to the Boss length, fairly easily for a good machine shop ?
Determined I'm going with a 12/71 kit from Hampton
John Myrick- BBF CONTRIBUTOR
Re: Shortening a Scat Crank
Yes and get it double keyed
What are the advantages to the boss length crank snout othere then more room between radiator and balancer in a N/A or nitrous engine?
68formalGT- Posts : 865
68formalGT wrote:What are the advantages to the boss length crank snout othere then more room between radiator and balancer in a N/A or nitrous engine?
Because the damper and pulley are closer to the front main bearing, it has less leverage so it is stronger in use.
rmcomprandy wrote:68formalGT wrote:What are the advantages to the boss length crank snout othere then more room between radiator and balancer in a N/A or nitrous engine?
I've heard you can have it set up for a small block damper or is it better to stick with a big block damper?
68formalGT wrote:rmcomprandy wrote:68formalGT wrote:What are the advantages to the boss length crank snout othere then more room between radiator and balancer in a N/A or nitrous engine?
YES ... a 3" long snout for using a small block damper has been done for years but, is now becoming popular.
Another option to snout shortening is that you can also play with blower hub and pulley orientation and get the lower pulley right up against the timing cover that way while keeping the standard length snout. This also leaves the future possibility of a bearing support if you care to add one, keeps the crankshaft more resellable to the masses, etc.
Is this a Boss snout then?
68formalGT wrote:Is this a Boss snout then?
3.600" is a Boss length snout.
» scat 9000 crank
» How to tell if a motor is externally or internally balanced
» SCAT CRANK KEY"S
» scat 4.5 crank
» IDT Block & Scat 4340 crank ?
» SCAT CRANK KEY"S
» scat 4.5 crank
