seal of piston rings
Rabbit
seal of piston rings Empty seal of piston rings
Post  Rabbit July 18th 2014, 5:21 pm
Do piston rings seal better when new or do they seal better after they ran after lets say 2000 miles the reason im asking is that im doing a leak down test block fresh out the machine shop with file fit rings
Rabbit
Rabbit
seal of piston rings Empty Re: seal of piston rings
Post  dfree383 July 18th 2014, 5:45 pm
they need to seat first.
Post  richter69 July 18th 2014, 7:44 pm
same
Post  Rabbit July 18th 2014, 9:18 pm
what if they were 80% pale .019 top a bottom
Rabbit
Rabbit
Post  69F100 July 18th 2014, 9:28 pm
New rings will have to seat to the cylinders before you will get a true reading I just about bet the leak down test will fell if the rings have not been seated yet.
Post  Rabbit July 18th 2014, 9:52 pm
man I sure hope so some thing like this can drive a man crazy all the way from the engine stand to the hood
Rabbit
Rabbit
Post  Larry T July 18th 2014, 10:12 pm
did you do a leak test on the valves before assembly to see if they were seated properly?you didn say how many miles you had on the motor.
Larry T
Larry T
Post  Rabbit July 18th 2014, 10:20 pm
brand new motor fresh out the machine shop $1700 worth still on the stand
Rabbit
Rabbit
Post  bbf-falcon July 19th 2014, 8:14 am
You need to let that NEW engine get really good and Hot at least 200/210* then let it cool down. They will seat. Very Happy
Post  Rabbit July 19th 2014, 8:00 pm
update I returned that cheap leak down junk scrap of a tool got a new one from NAPA boy did that make a differece 23%-17% across the board cheers you live and learn DO NOT BUY CHEAP TOOLs
Rabbit
Rabbit
Post  c.evans July 19th 2014, 8:47 pm
I tell my guys to never do a cold leakdown test anyway. The results from a cold test are as useless as tits on a boar hog. Always do a leakdown test with a very warm engine.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Rabbit July 20th 2014, 9:55 am
c.evans wrote:I tell my guys to never do a cold leakdown test anyway.  The results from a cold test are as useless as tits on a boar hog.  Always do a leakdown test with a very warm engine.
Hope this helps,
Charlie
  C.Evans how much of a difference is there between a warm and a cold engine by your experience when doing a leak down test 5% 10%
Rabbit
Rabbit
Post  c.evans July 20th 2014, 10:19 pm
The percentage varies, but I've seen it be over 20%. Couple of my guys have called with their panties in a wad, telling me it's got 18% leakdown or some number, and then when they tell me it was cold, they get a butt chewing for even bothering me. I tell them to do it hot and then call me back,,, when they do, they're are kind of sheepish because now it's 3 or 4%.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
