What motors better for a buildup?
quick 52
Rabbit
bronco911
Picked up 3-429's and a 460 out of a 76 Lincoln last night, wondering which one will be best for a build 5-700 ish
1-c9veb block with c9vea heads
2- diveAA's blocks with dove heads
Or, the 460 (did not feel like scraping the oil off it to read the numbers)
Thanks, Ray
Thanks, Ray
bronco911- Posts : 103
Re: What motors better for a buildup?
well im not sure if the C9VE are are as good as the DOVE blocks but if I was to pick it would be the D1VE just because of the taller deck and if it had the stock bore 4.360 that would be a pulse but 750hp well I think all of them could handle it as so as they can pass a magnaflux or all the other ways to test for cracks but I would not go past the 850 mark with a stock block but that's just me there has been people that done 850+ all day
Rabbit- Posts : 57
Put the early heads on the 460 and hope the exhaust seats don't recede...
Whatrmcomprandy wrote:Put the early heads on the 460 and hope the exhaust seats don't recede...
quick 52- Posts : 612
quick 52 wrote:Whatrmcomprandy wrote:Put the early heads on the 460 and hope the exhaust seats don't recede...
X2
Randy is saying that you run the D0VE heads and hope that the non hardened exhaust seats dont burn. Kind of a sunken valve problem.
Dave De- Posts : 797
I am going to take a wild guess and figure that you guys have no experiences about the use of heads with UN-hardened exhaust valve seats and the potential resultant issues with using unleaded gasoline.
Ignorance is bliss ... so, never mind, forget I said anything.
"Good judgement comes from experience and, experience ...well, it comes from bad judgement", Ben Franklin
I'd do like randy said as start with a 460 crank in any of the blocks and pick the best looking early heads. And like he's saying they will wear the exhaust seats. But as long as your not expecting to build a high mileage engine it's an issue but one that typically will take a while to surface.
Now to the goal...... 500 is not a super high goal at it can be achieved with a reasonable effort with the parts you have and a modest budget...... 700 is a whole lot more work and cost depending on your ability and is going to hard on pump unleaded gas with the heads you have.
Not a mind reader but perhaps he was asking which Block to use as a foundation. Or perhaps he meant which starter "Motor"
D. Sea- Posts : 2768
D. Sea wrote:Not a mind reader but perhaps he was asking which Block to use as a foundation. Or perhaps he meant which starter "Motor"
Yeah, that was pretty much my intent, wondering which block would be best, if any difference at all
The ones you have listed are typically all about equal. Unless you sonic test them for cylinder wall thickness. The earlier blocks do have a little shorter deck, but that's not a big deal.bronco911 wrote:D. Sea wrote:Not a mind reader but perhaps he was asking which Block to use as a foundation. Or perhaps he meant which starter "Motor"
I'd go with the c9.IMO the casting is a little better quality than the later.unless you have one of the few d1ve blocks with thick mains!
Just went thur the sunken valve thing they looked like a sink hole in fla so I had harden seats and bronze guilds and be done with it my heads were 71 DOOE-R that's why I spent the $ on them
Super Snake Steve- Posts : 141
» What do you guys rev your motors to??
» OK who knows what about blower motors
» big inch motors..
» 2009 EMC Motors
» MOTOR CITY MOTORS
» big inch motors..
» 2009 EMC Motors
» MOTOR CITY MOTORS
