balancer questions
+6
kim
norm
garys gt
10 posters
balancer questions
do the ati balancers need the spacer like the i/w balancers ? i am trying pick out a balancer for a 557. from what i have read ati, ford racing, and i/w are all good products. i noticed ati had a few different balancers. some were little over 6" o.d. and some little over 7" o.d. so what is the benefit of one over the other ? also noticed they had 3 bolt holes for the pulley. dont most ford pulleys have 4 bolts. or was that a generic picture.
garys gt- Posts : 87
Re: balancer questions
I believe the three bolt pattern will use big Chevy pulleys and it will still use the spacer.
norm- Posts : 261
garys gt wrote:do the ati balancers need the spacer like the i/w balancers ? i am trying pick out a balancer for a 557. from what i have read ati, ford racing, and i/w are all good products. i noticed ati had a few different balancers. some were little over 6" o.d. and some little over 7" o.d. so what is the benefit of one over the other ? also noticed they had 3 bolt holes for the pulley. dont most ford pulleys have 4 bolts. or was that a generic picture.
The I.W. unit for the std long snout are 4 bolt.....the ones for the shorter Boss style snout are 3 bolt chevy patterns.
Is your crank stock long snout or short? Belt drive or chain?
timing chain and it's a probe rotating assembly (crank is built by scat i believe) so I think it's long but not sure. Haven't got it out of the box yet.cool40 wrote:Is your crank stock long snout or short? Belt drive or chain?
So the spacer is used with all of the balancers ? What is the reason for 6" and 7" diameter balancer ? Bigger balancer absorb more ?
Mine is a 7" ATI
Pump and accessory clearance, crank triggers, an option for options....
kim- Posts : 700
Those I/W's sure are pretty
Mike R- Posts : 1381
Do all of the balancers take a after market timing pointer ? Or can a factory pointer be used ?
garys gt wrote:So the spacer is used with all of the balancers ? What is the reason for 6" and 7" diameter balancer ? Bigger balancer absorb more ?
The I.W. short snout dampers do not use a spacer...the only one that I'm aware of that does not .
Are all the neutral balance spacers the same other than material there made from ?
With the IW long snout can you use the factory spacer or does it have to be shortened?
very similar.
garys gt wrote:Are all the neutral balance spacers the same other than material there made from ?
Yes. And don't fear the aluminum.... searched high and low to get a "iron" spacer. Aint worth the headache.
kim- Posts : 700
SandHillsHillbilly wrote:With the IW long snout can you use the factory spacer or does it have to be shortened?
Needs to be 2.300"....shorter than the stock ~ 2.750".
kim wrote:garys gt wrote:Are all the neutral balance spacers the same other than material there made from ?
I agree,they are just what they are "spacers".
Lem Evans wrote:SandHillsHillbilly wrote:With the IW long snout can you use the factory spacer or does it have to be shortened?
Lem will FE spacer work they are shorter than the 385 stock I am not sure how much?
http://www.innovatorswest.com/app-BBF.html
460pulling- Posts : 249
» 429 QUESTIONS
» 460 fox questions
» New combo Idea for my 73 mustang....
» BBF 460 Questions
» 572 questions
» 460 fox questions
» BBF 460 Questions
» 572 questions
