spark plug heat range
What would be a good or ideal spark plug range for the following engine combo running on all motor only? I am currently ngk #9. Im wondering if a #8 will give me a performance gain
598ci
14.5 to 1 comp
1600 cfm carb
crank trigger
a460 heads/intake
2 1/4 headers
34 degrees of timing
2 speed power glide. 1.80 1st gear
4.30 rear gear
2780lbs with driver
598ci
14.5 to 1 comp
1600 cfm carb
crank trigger
a460 heads/intake
2 1/4 headers
4.30 rear gear
2780lbs with driver
deliveredfast- Posts : 358
Re: spark plug heat range
time for that nawws it sounds like...... but id put a 10 in it first.
» Plug heat range for a SBF...?
» Spark plug help.
» Lets Talk heat range of spark plugs
» Spark Plug Range & Gap W/Higher Compression?
» spark plugs for 466 with 14 to 1 comp
» Spark plug help.
