Plug heat range for a SBF...?
Just curious if anybody has run anything other than stock replacement Autolites ot Motorcrafts. It's got a set of 69-70 big plug stye heads on it...
It's been years since I fooled with them. I haven't retained all that knowledge...
jbozzelle- Posts : 3705
Re: Plug heat range for a SBF...?
I'm thinking I used to run a 32s on the spray and 52s on the motor... All the parts stores say 42s
Thanks Randy. Does a 42 sound hot enough for a pump gas street engine?
jbozzelle wrote:Thanks Randy. Does a 42 sound hot enough for a pump gas street engine?
Yes Joe, they will work fine as long as evrything is in good shape.
Dave.
LivermoreDave- Posts : 972
» Spark Plug Range & Gap W/Higher Compression?
» spark plug heat range
» spark plugs for 466 with 14 to 1 comp
» spark plugs
» Lets Talk heat range of spark plugs
» spark plugs
