Lets Talk heat range of spark plugs
kim
gt350hr
t-bird racer
I have been running the NGK R5673-10. My combo is a 521 BBF naturally aspirated. This plugs have been the only plug I have had since the dyno
pulls and tuning a few years back by my engine builder. Everything I read says these plugs are meant to be used in high boost/nitrous applications.
Would a set of #9's or 8's be better suited for a drag race application? How would this effect the tune up/ performance of the engine. I have not been
having trouble just curious as to the difference.
Any and all comments are welcome.
t-bird racer- Posts : 193
Re: Lets Talk heat range of spark plugs
What do they look like?
That is a colder plug than what most people run NA.
whatbumper- Posts : 3024
That is the coldest plug offered. I ran it on a cast iron head with 14-1 c/r and it was fine. I tried a -9 and it showed some overheating. For an aluminum head and or less compression ratio , I would look at a hotter plug.
gt350hr- Posts : 662
It's an Aluminum Headed engine around 13 to 1 compression.
I'm just not that good at reading plugs.
I run that plug with alinum heads 17-1 compression and a 500 shot.
kim- Posts : 700
The 8 works in most NA setups.
+1 I would use a -8 on an aluminum head with 13-1. The aluminum head sucks heat out of the plug far better than an iron head does and is the reason a warmer plug can be used.
Truly,
I can't recall any color on the plugs they stay pretty clean. I have not spent too much time racing the last few years, so trying to
remember. It seemed that it started a little hard, maybe a hotter plug would help it fire quicker on start up.
I remember that i would warm the car, on a old set of plugs and then put fresh plugs in before my time runs.
I think I got -10 because that's what the shop had and i never tried any other plugs..
Thanks for the help.
cool40 wrote:The 8 works in most NA setups.
Agreed
How would these compare to a Autolite Racing plug? How do these numbers cross reference?
away- Posts : 266
away wrote:How would these compare to a Autolite Racing plug? How do these numbers cross reference?
Something like an AR12
we had a new set of autolite racing plugs that would hardly run. Searched for the problem a while before figuring it out. They looked like a bad monday morning job or autolite may be buying from china? Replaced with ngk-9 and it sounded normal again. so we wont be useing autolite plugs anymore. https://2img.net/h/i206.photobucket.com/albums/bb173/nbjuljetta02/Spark-Ref.jpgaway wrote:How would these compare to a Autolite Racing plug? How do these numbers cross reference?
cool40 wrote:we had a new set of autolite racing plugs that would hardly run. Searched for the problem a while before figuring it out. They looked like a bad monday morning job or autolite may be buying from china? Replaced with ngk-9 and it sounded normal again. so we wont be useing autolite plugs anymore.away wrote:How would these compare to a Autolite Racing plug? How do these numbers cross reference?
Did you run a plugfax on them....could be a salvage title deal
these were new,in the box,OEM autolite racing plugs but looked about as quality as a champion!Lem Evans wrote:cool40 wrote:we had a new set of autolite racing plugs that would hardly run. Searched for the problem a while before figuring it out. They looked like a bad monday morning job or autolite may be buying from china? Replaced with ngk-9 and it sounded normal again. so we wont be useing autolite plugs anymore.away wrote:How would these compare to a Autolite Racing plug? How do these numbers cross reference?
I was also told that Auto-lite plugs went to china! So you are probably right.
So what would the recommendation be for a naturally aspirated bracket car methanol injection. TFS street head
away- Posts : 266
ngk #8 is what I run.away wrote:I was also told that Auto-lite plugs went to china! So you are probably right.
We also use #8 in N/A stuff and even in some small nitrous stuff
gmsmkr- Posts : 1364
NGK Spark Plugs R5671A-8 - NGK Racing Spark Plugs
Autozone part number 4554?
Is this the part number?
away- Posts : 266
away wrote:NGK Spark Plugs R5671A-8 - NGK Racing Spark Plugs
Yes
So,
Here is a follow up question. I normally run the -10 with 87 Carb Jets. If I switch to the hotter -8 should I go up a jet
or two to accommodate the hotter plugs??????
Fuel should have been right regardless the plugs temp. Most noticable diffrence will be start up. Crisper
kim- Posts : 700
Well I finally was able to make a few passes and the car ran pretty consistent. Here is a picture of the #5 cylinder after my first time run. These are the #8 NGK's. I did have to idle a bit on the way back to the pits. Any and all comments are welcome.
Heat range looks good. Fuel line ok, maybe a little rich. I see a few specs, might want to drop timming a degree or two. Few oxide of n20 fecs.
kim- Posts : 700
Timing is at 31 or 32 degrees. Thanks for your response.
» spark plug heat range
» spark plugs for 466 with 14 to 1 comp
» Plug heat range for a SBF...?
» P 51 spark plugs
» spark plugs
» P 51 spark plugs
» spark plugs
