tuning for street
tuning for street Empty tuning for street
Post  stanggt September 16th 2014, 10:01 am
I am running a lot of power and torque in my 420 cu street car and really need more bite. Currently have team Z lower DA lowers with DA uppers and stock v8 springs with one coil cut off and strange adjustable shocks. Im about 3/4" spread between bolts on lower control arms. New Nitto drag tires 27" tall. 4:10 gears. Coil over front strut conversion. C4 with Bp 3500 converter. Any input from experience would help. I did down load baselines guidelines
stanggt
stanggt
tuning for street Empty Re: tuning for street
Post  yellowhorse7 September 16th 2014, 11:21 am
stanggt wrote:I am running a lot of power and torque in my 420 cu street car and really need more bite. Currently have team Z lower DA lowers with DA uppers and stock v8 springs with one coil cut off and strange adjustable shocks.  Im about 3/4" spread between bolts on lower control arms. New Nitto drag tires 27" tall. 4:10 gears. Coil over front strut conversion. C4 with Bp 3500 converter. Any input from experience would help. I did down load baselines guidelines
Are you talking race car or cruiser?
If you mean street-raced car, then you won't get much help. I'll volunteer that street-raced cars like anti-squat. For a cruiser, gonna be a hard compromise
yellowhorse7
yellowhorse7
Post  stanggt September 16th 2014, 11:42 am
Its raced but we do it locally on airport runway at organized events. Its asphalt just like our streets. Can't get any real good traction. Car don't seem to squat much. Can't run slicks either, dot tire
stanggt
stanggt
Post  whatbumper September 16th 2014, 12:58 pm
Get on a flat surface and measure to the centers of the control arm bolts and either post or pm me those numbers as well as the actual measurement to the fender lips front and rear.
Post  stanggt September 16th 2014, 1:10 pm
Will do.
stanggt
stanggt
Post  stanggt September 16th 2014, 1:29 pm
Lower arms at 9 11/16 back bolt and 10 1/8 front bolt. Less difference than I thought and rear wheel wells are 28 1/16 , front is 26 5/8.
stanggt
stanggt
Post  whatbumper September 16th 2014, 8:59 pm
stanggt wrote:Lower arms at 9 11/16 back bolt and 10 1/8 front bolt. Less difference than I thought and rear wheel wells are 28 1/16 , front is 26 5/8.
Sorry I forgot to clarify. I need the upper measurements to the bolts as well. I will use the factory lengths unless you think you've moved them a lot from stock. I'll punch them in the computer in the morning when I get to the shop.
Post  stanggt September 16th 2014, 9:14 pm
Will get them in the morning. Thanks
stanggt
stanggt
Post  stanggt September 17th 2014, 2:03 pm
9 1/4" on the uppers
stanggt
stanggt
Post  stanggt September 17th 2014, 2:07 pm
Did you need from ground to upper bolts also? I just gave you center to center.I will get them.
stanggt
stanggt
Post  stanggt September 17th 2014, 2:22 pm
Hard to get an exact measure on uppers cause I have team Z solid spherical bushings. Both are about 16 11/16 and they have a 1 1/2 degree angle down in the front and lowers have the same degree angle up at the front.
stanggt
stanggt
