Camshaft Regrinding?
+6
Bill Heard
lghting94
10 posters
Camshaft Regrinding? Empty Camshaft Regrinding?
Post  lghting94 October 17th 2014, 5:01 pm
What can be changed/done when having a camshaft reground? I have a couple solid roller camshafts that are to large for my currently planned engine and was wondering if it would be cost effective or even possible to send them back and have them reground to a smaller lift/duration?
lghting94
lghting94
Camshaft Regrinding? Empty Re: Camshaft Regrinding?
Post  dfree383 October 17th 2014, 5:04 pm
Yes it can be done, but their are limits in how much the specs can be changed. And you need to watch the hardness, some times you can go thru.
Post  Lem Evans October 17th 2014, 5:35 pm
Like Dfree said.....there is limit to how much change a guy could make and keep the heat treat area. It'd matter also if you want to change the lsa too.
What are the lobe #s and lsa?
Post  maverick October 17th 2014, 6:39 pm
Is "re-heat treating" not done, or does that simply make it too expensive to be worthwhile?
Post  Lem Evans October 17th 2014, 6:46 pm
maverick wrote:Is "re-heat treating" not done, or does that simply make it too expensive to be worthwhile?
Sometimes it could get to that point....regrind + heat treat and extra shipping could kill a deal.
Post  Bill Heard October 17th 2014, 8:55 pm
You can call my brother Ken Heard @ Oregon Cam Grinding. 503-252-5505. He's been re-grinding cams for many years. He also races a big block Ford.
Bill Heard
Bill Heard
Post  cool40 October 17th 2014, 10:10 pm
Bullet did one for me for 125$ i think it was.
Post  lghting94 October 17th 2014, 10:20 pm
One of the two cams I have is a very old crower that I had the card for I just have to find it again. The other I got with some other parts from a pulling truck engine. That cam is a Schneider Cam and I didn't get a card with it I measured it once but don't remember those specs
lghting94
lghting94
Post  dfree383 October 17th 2014, 10:47 pm
FE guys out here love Oregon Cams another west coast choice is Delta Cams in Tacoma they are some nice guys too.
Post  68formalGT October 18th 2014, 1:30 pm
dfree383 wrote:FE guys out here love Oregon Cams another west coast choice is Delta Cams in Tacoma they are some nice guys too.
Delta cams re ground my cam, in use for 3 years and no problems with it. Solid flat tappet from a hydraulic flat tappet.
Post  c.evans October 19th 2014, 7:04 pm
lghting94 wrote:One of the two cams I have is a very old crower that I had the card for I just have to find it again. The other I got with some other parts from a pulling truck engine. That cam is a Schneider Cam and I didn't get a card with it I measured it once but don't remember those specs
The Schneider Cam is likely a cast core cam and already a regrind itself. I'd check for that before I used it again.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  gt350hr October 22nd 2014, 11:48 am
Cast iron cams are through hardened , not surface hardened like rollers. They do not need to be re heat treated.
gt350hr
Post  DaveMcLain November 1st 2014, 8:04 am
The problem I see is that you are trying to go "smaller" with the cam and this can be tough to do on a regrind. Going larger with more lift is generally easier to do because in the regrinding you'll be taking material away from the base circle and not much at all from the flanks and nose. Even if you go through the heat treat on the base circle it won't cause any harm.
DaveMcLain
