regrinding a cam shaft
fatal addiction
can i have a cam reground to make it smaller? thanks
fatal addiction- Posts : 433
Re: regrinding a cam shaft
fatal addiction wrote:can i have a cam reground to make it smaller? thanks
Depending on the cam you can have it reground and made bigger. You can't change the lobe sep but lift and duration can be changed.
G-
G-Code- Posts : 193
Depends on the core used some are better than others
Most of the time a cam can be reground to new specs, bigger smaller etc. You will be somewhat limited to what can be done and you won't be able to change the lobe separation by more than a few degrees, usually. I've had cams reground quite a few times flat tappet as well as roller and I've never had a problem.
DaveMcLain- Posts : 399
» Camshaft Regrinding?
» Regrinding Roller Cam
» Kasse oil pump problem
» msd distributor in 460 block
» Aluminum Drive Shaft
