Casting number help
Casting number help
I've got a complete engine with a block casting number DIVE6015A. I was wondering if they were worth anything? Any info would be appreciated.
jason- Posts : 220
Re: Casting number help
It worth something if someone needs one, but it's not a special or rare part.
so the heads aren't worth much?
jason- Posts : 220
DP
You haven't give the head casting numbers, but most heads that come on D1 casting blocks with the exception of the very early ones and police heads are not worth much.
Blocks will go from $100-300 depending on condition or how bad someone needs one. Other small stuff is worth a few $.
You're not sitting on a small fortune it that's what you're asking. But the parts are good for a build.
Dove 9425b is on the intake and all I can find iswhat looks like a dk17 or ok17 on the heads
jason- Posts : 220
If the heads have D0VE on them they are worth $150-200 for the castings. They are small chamber Thunder Jet Castings. (Not Cobra Jet)
ok thanks for the help
jason- Posts : 220
What are dove-c heads worth?
jason- Posts : 220
see abovejason wrote:What are dove-c heads worth?
so c's are common? Thanks again.
jason- Posts : 220
Yes, but they are a more desirable small chamber casting like C8 an C9 ones
» Same old 429/460 question
» New TFS Intake Manifold ...pics
» Casting numbers
» Connecting rod casting numbers?
» 302 block casting #??????
» Casting numbers
