Casting numbers
Casting numbers
Well, gonna tear down this engine to get to the machine shop. Have a few casting number questions. The casting number is a D1VE-A2B. What was last year for 429?
Chopperchip- Posts : 63
Re: Casting numbers
I think somewhere in 1973 was the last year for the 429. This link to block info will provide some information about Ford's revision numbers.
https://www.429-460.com/t120-block-info-gathered-by-djohagin
Re: Casting numbers
Doug Rahn wrote:I think somewhere in 1973 was the last year for the 429. This link to block info will provide some information about Ford's revision numbers.
The Heavy truck / industrial 429 was used right up to 1998, I believe. It replaced all the FE truck engines in 1982.
The D1VE casting number was used from 1971 till 1978.
Re: Casting numbers
rmcomprandy wrote:Doug Rahn wrote:I think somewhere in 1973 was the last year for the 429. This link to block info will provide some information about Ford's revision numbers.
Thanks Randy! I had heard that also, just never knew it to be for sure so I didn't bring it up. I had also heard some 429's may have made it into early 1974's.
Re: Casting numbers
Will this d1ve block take 650-700 hp?
Re: Casting numbers
Chopperchip wrote:Will this d1ve block take 650-700 hp?
Yes it's done all the time
Re: Casting numbers
dfree383 wrote:Chopperchip wrote:Will this d1ve block take 650-700 hp?
been making more than that on my D1ve block and offset ground ford cast crank for the last 6 years. hurt a piston or 2 that needed to sleeve some cylinders, but the rest has been running strong!
kjett- Posts : 1169
» Connecting rod casting numbers?
» door-e casting
» Wanted: Fox throttle body and upper intake with these casting numbers....
» ? on 63 model 390 heads
» Casting number help
» door-e casting
