Ford Casting Numbers
Anyone have any ways of looking up old Ford casting numbers? I'm looking for another rear drum with C2800A on it. It is a 11 inch drum, 4.5 inch bolt pattern, about 2 inch wide, but don't know what kind of 1962 on up, Ford car it came off of. Thanks
Mark460- Posts : 31
Re: Ford Casting Numbers
that is not a casting number or not enough of one.It can't start out like that.Should read something like c20a-1126-a or a lot of different numbers depending on car or truck.hope this helps,or if you have the whole casting number call me toll free 1-800-632-1034 ext 3531, and I'll try to help you out.Michael
PROSTREET66- Posts : 245
» Casting numbers
» 302 block casting #??????
» Wanted: Fox throttle body and upper intake with these casting numbers....
» Carb Spacer - Airflow Test
» ? on 63 model 390 heads
