521" pump gas engine
+17
460bronco
nuclearcobra
68galaxie
quick 52
514F-1
jones
droppedf100
whitefield
Fla Fairlane
jeffgfg
61coon
gmsmkr
21 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: 521" pump gas engine
Please don't ruin a great post about a very well built 521".
No one said this was BS anyhow. Great build Lem!!
68galaxie- Posts : 351
68galaxie wrote:Please don't ruin a great post about a very well built 521".
This is almost identical build to my engine except my heads, intake have been ported, solid roller camshaft and 4500 carb.
jones- Posts : 2230
Not sure where the limit is, but Lem had a pretty big solid flat tappet made for the combo i'm starting soon for a friend and said we should see 800 , these guys know these motors for sure , Scott Johnson , Roger at Kaase , Carl Hansen, Dave Freelander all said the same thing , the combo is a 14to1 552 with P51 heads and a mafia intake with a 1250 quick fuel carb , my friend knows he's leaving some good hp on the table not going the solid roller route , but he wants to try this first then maybe next season step up to a roller with some head and intake work.droppedf100 wrote:That is badass with pump gas and a solid flat tappet. Where is the limit in a flat tappet? Could a cam be grinded to make good power with a460 heads?
nuclearcobra- BBF CONTRIBUTOR
nuclearcobra wrote:Not sure where the limit is, but Lem had a pretty big solid flat tappet made for the combo i'm starting soon for a friend and said we should see 800 , these guys know these motors for sure , Scott Johnson , Roger at Kaase , Carl Hansen, Dave Freelander all said the same thing , the combo is a 14to1 552 with P51 heads and a mafia intake with a 1250 quick fuel carb , my friend knows he's leaving some good hp on the table not going the solid roller route , but he wants to try this first then maybe next season step up to a roller with some head and intake work.droppedf100 wrote:That is badass with pump gas and a solid flat tappet. Where is the limit in a flat tappet? Could a cam be grinded to make good power with a460 heads?
The P-51's are a good head candidate for a flat tappet cam too............. Your deal with the right cam will best 800 a good bit.
Hello Nuclear,
Is the flat tappet made for this combo using a .904" lifter? or larger?
Would be very interesting to see the limit of a solid ft cam - with larger lifter diameters.
How ported are the heads? Care to share any flow numbers? Also what ball park duration does the cam have?
Thanks,
Jon
Thanks,
Jon
460bronco- Posts : 364
Just normal size Comp edm lifters, and the heads and intake are box stock.
460bronco wrote:How ported are the heads? Â Care to share any flow numbers? Â Also what ball park duration does the cam have?
Thanks,
Jon
This the deal for the 521" that I posted.......
The intake side of the heads are 375ish cfm. There was no intent or attempt to make a 400 cfm port. Things were size to fit the application.
Lem Evans wrote:460bronco wrote:How ported are the heads? Â Care to share any flow numbers? Â Also what ball park duration does the cam have?
Thanks,
Jon
Simple bowl porting and a back-cut angle on the intake valves will get near that air flow amount with those heads so, I am sure this was nothing drastic. Â
AND, peak air flow is just not the place where those SCJ heads show themselves ... .300" to .550" valve lift is where they really shine.
Nice valve covers! Wish the picture was larger. What is the engraving? Is that like decals more HP?
Lem Evans wrote:
One day my wife will let me finish my truck!
jones- Posts : 2230
Not looking for an exact figure or a "Quote" but ball park how much would this build cost minus labor for engine assembly.
Looking at ideas for a future "Street" project.
D. Sea- Posts : 2768
Lem Evans wrote:Your phone # still end in 5383?
Yassir, I have a few blocks, need to do something with them i.e. Fill the insides with rotating metal LOL! Lem this isn't something I'll get started on right away, most likely be this winter or maybe next spring before I get started. I have a few other projects going on right now that take priority.
I would like to mail you a money order for the blueprints of that build in the spring/summer for my 521 so after I get the block back from local bowtie/rat-nick machine shop I can assemble it correctly. Fire it, and have a beer or 3 (8-10) after breaking in the cam then go hunting at later dates. Great build, thanks for sharing I think I got the jist but the details are everything.
FalconEh- Posts : 1448
Is it a bad internet service thing, or why is the pic in the OP missing? No picture of the pull.
J.Toney- Posts : 398
J.Toney wrote:Is it a bad internet service thing, or why is the pic in the OP missing? No picture of the pull.
It's a photo bucket rape deal.........new stuff is applied
Thanks greybeard!! Same or similar thoughts on a SFT cam these days? Have one needing sorting of details and then assmeble. ~13:1 521 w/SCJA's. Just boxes at the moment.
Page 2 of 2 • 1, 2
» New Projects ???
» 521 A-Head Pump Gas Engine
» 528" Pump gas engine 840HP
» 572 P-51 Pump Gas Street Engine
» Newer oil pump on an older engine.
Page 2 of 2
