Engine combo comparison opinions
85bigblockfox
whitefield
Engine combo comparison opinions Empty Engine combo comparison opinions
Post  whitefield December 2nd 2014, 11:27 pm
1st 466 DOVE-C heads professional port and valve job by a Ford engine builder( no flow numbers the flow sheet burned up in shop fire) Crying or Very sad 2.19 intake 1.76 exhaust valve size.
vic intake 1050 carb
2'' primary long tube headers 4'' collector
14.1:1 compression
hyd. flat tappet cam with matching lifters and springs
1.73 lunati roller rockers
cam specs
intake .618 exhaust .618
duration @.050 268 intake 268 exhaust
lsa 110 cam installed 4 degrees advanced
6500 max rpm
2nd 466 box stock 460 #61669 Edlebrock heads
2 '' primary long tube headers into 4'' collector
12.1:1 compression
solid roller cam with matching lifters and springs
1050 carb with vic intake
cam specs
intake .728 exhaust .710
duration @ .050 258 intake 270 exhaust
lsa 112 2 degrees advance
7000 max rpm
In your opinion will these two engines be with in 50 hp of one another ? if so which one will make the higher hp number ?
thanks for any and all opinions
whitefield
whitefield
Engine combo comparison opinions Empty Re: Engine combo comparison opinions
Post  the Coug December 3rd 2014, 7:13 am
nice jab
Post  whitefield December 3rd 2014, 7:21 am
the Coug wrote:nice jab
No Jab ! Been wanting to ask this question for sometime now !
whitefield
whitefield
Post  85bigblockfox December 3rd 2014, 9:42 am
The iron headed build is almost identical to the motor in my car. I dont think the et matches the dyno numbers. But it has been a 10.91 @ 123 at 3385lbs. On the dyno it made 442rwhp/422ftlbs through the c6.
85bigblockfox
85bigblockfox
Post  IDT-572 December 3rd 2014, 11:18 am
Mike that second engine, is almost a perfect match to a guy in Tullahoma you know the guy, his deal ran a 6.20 right off the trailer @ 3000 lb.
The top deal will run about a 6.60-6.80 at that weight. If the heads flow in the 330-340 range.
Post  IDT-572 December 3rd 2014, 11:20 am
I would guess almost 100 hp difference................
Post  rmcomprandy December 3rd 2014, 12:54 pm
whitefield wrote:1st 466 DOVE-C heads professional port and valve job by a Ford engine builder( no flow numbers the flow sheet burned up in shop fire) Crying or Very sad   2.19 intake 1.76 exhaust  valve size.
14.1:1 compression
cam specs
6500 max rpm
12.1:1 compression
cam specs
7000 max rpm
Completely different applications ... not even near the same realm.
Post  bbf-falcon December 3rd 2014, 3:32 pm
Yea,not even a close match. Shocked
Post  whitefield December 3rd 2014, 7:25 pm
I have to ask would a solid roller cam help get the 1st 466 closer to the 2nd 466?
I also know the first 466 isn't very street friendly with the compression it has.
whitefield
whitefield
Post  whitefield December 3rd 2014, 7:26 pm
IDT-572 wrote:Mike that second engine, is almost a perfect match to a guy in Tullahoma  you know the guy, his deal ran a 6.20 right off the trailer @ 3000 lb.
Yeah I had forgotten about him running that set up ! Surprised thanks
whitefield
whitefield
Post  whitefield December 3rd 2014, 7:30 pm
85bigblockfox wrote:The iron headed build is almost identical to the motor in my car. I dont think the et matches the dyno numbers. But it has been a 10.91 @ 123 at 3385lbs. On the dyno it made 442rwhp/422ftlbs through the c6.
Thanks I was trying to get an Idea on how I should build my next engine. I want to get power and performance with street ability and on a budget.
whitefield
whitefield
Post  Mike R December 3rd 2014, 7:55 pm
You're wasting your time with a 460. From everything I've been reading and been told lately you can make like 4000 hp on 87 pump gas with an LS with some simple, bolt on mods lol! lol! lol!
Post  whitefield December 3rd 2014, 8:35 pm
Yeah that's all you hear about ! Rolling Eyes
I will stick with my 351w and 460's !
whitefield
whitefield
Post  85bigblockfox December 4th 2014, 9:34 am
I didnt catch the flat tappet cam. Mine has a solid roller in it I cant remember the duration but the lift is .631.
85bigblockfox
85bigblockfox
Post  whitefield December 4th 2014, 9:01 pm
Yeah I was hopping to run a custom solid roller cam and pick up some power ! But was also hopping that the two engine combos would be in the ball park too ! scratch study
whitefield
whitefield
