Valve Cover Gaskets
+13
powerstrokeace
GT300TD
10SHOTS
dragsterdick
17 posters
Valve Cover Gaskets
What is the best non-leaking valve cover gasket? Type and brand?
dragsterdick- Posts : 54
Re: Valve Cover Gaskets
I have the Cometic vc gaskets on mine. Have held up great. No leaks in 2 years. The previous FRPP/FelPro (steel core w cork on each side) gaskets were decent when new, but after a few times removed top run valve they leaked and were getting torn up.
David Cole wrote:I have the Cometic vc gaskets on mine. Have held up great. No leaks in 2 years. The previous FRPP/FelPro (steel core w cork on each side) gaskets were decent when new, but after a few times removed top run valve they leaked and were getting torn up.
Does Felpro not make the rubber ones for the 460?
FalconEh- Posts : 1448
Summit has a shit ton of Trick Flow rubber gaskets in their clearance section (Tallmadge).
jasonf- BBF CONTRIBUTOR
Get the Cometic ones they are da bomb!
THX-X2
I had a set of cometics once , I'm sure they work well in some applications but they weren't so great with the tall ford racing valve covers , those covers have little raised up round things on the bottom and the cometic gaskets are hard and don't compress well causing a leak , that's just my experience with them
10SHOTS- Posts : 587
yep, I run mine over a big belt sander to get that and the "Taiwan"lettering off.I also had a little groove in a vc rail cause a problem with the cometics but after a few heat cycles it sealed up.10SHOTS wrote:I had a set of cometics once , I'm sure they work well in some applications but they weren't so great with the tall ford racing valve covers , those covers have little raised up round things on the bottom and the cometic gaskets are hard and don't compress well causing a leak , that's just my experience with them
Cometics need a thick billet rail and need to be flat and smooth. ive got some flatouts here that are badass.... But they aint cheap either.
Valve Cover Gaskets
Thanks guys for all the info and Happy Holidays!!
richter69 wrote:Cometics need a thick billet rail and need to be flat and smooth. ive got some flatouts here that are badass.... But they aint cheap either.
The Cometic stuff is the best....unless the valve covers sux.
FalconEh wrote:David Cole wrote:I have the Cometic vc gaskets on mine. Have held up great. No leaks in 2 years. The previous FRPP/FelPro (steel core w cork on each side) gaskets were decent when new, but after a few times removed top run valve they leaked and were getting torn up.
They show them in the Summit Catalog FEL-1617,i've always had good luck with the rubber Fel-Pros.
Mark Miller- Posts : 1959
jasonf wrote:Summit has a shit ton of Trick Flow rubber gaskets in their clearance section (Tallmadge).
Were they for 429-460 and what day were you there?I might have to stop there on Monday and see if they still have some.
Thanks.
I'm like Jason when I have the good fortune of being in that area.I head straight for the corner of the store where the returns and discontinued items are.
bbf-falcon wrote:I'm like Jason when I have the good fortune of being in that area.I head straight for the corner of the store where the returns and discontinued items are.
ABSOLUTELY
GT300TD- BBF CONTRIBUTOR
I got 2 sets from Kaase and they were $45 a pair. but boy they are thick and dont leak a drop. i have no idea who made them
Ace
powerstrokeace- Posts : 1496
I use the Moroso silicone gaskets with the steel core, love'em.
BigRigTech- Posts : 763
For valve covers which are not absolutely flat ...
I use the Fel-Pro 5/16" thick gaskets with the sandwiched metal support.
Mark Miller wrote:jasonf wrote:Summit has a shit ton of Trick Flow rubber gaskets in their clearance section (Tallmadge).
Thanks.
Yes 460. I was there several times in Dec and they had 3 boxes full of them.
jasonf wrote:Mark Miller wrote:jasonf wrote:Summit has a shit ton of Trick Flow rubber gaskets in their clearance section (Tallmadge).
Thanks.
I was there on Monday i found 1 set they were $16.00,i didn't buy them spent to much money on a cat back exhaust for the daily driver truck.
Just one set?
ne set?
With my valve covers and where my master cylinder is located, it is not possible to get a bolt in the lower rear driver side. Obviously I had a leak issue. Tried several different gaskets (not the cometics though) and I was suggested to try doubling up cheap Felpro cork gaskets. Glue two together to make one soft, thick gasket. Has worked out very well for me.
soupbean- Posts : 637
» Trying out some edelbrock valve cover gaskets
» valve cover gaskets
» Valve cover Gaskets
» valve cover gaskets ......
