1996 f-250 speedo / ABS
1996 f-250 speedo / ABS Empty 1996 f-250 speedo / ABS
Post  glenevans January 5th 2015, 12:15 pm
My 1996 f-250 ABS light came on and the speedometer needle is jumping around. I checked all the fuses, would the sensor in the top of rear differential cause these problems ?
glenevans
1996 f-250 speedo / ABS Empty Re: 1996 f-250 speedo / ABS
Post  61coon January 5th 2015, 12:51 pm
The first thing I would check is the VSS (sensor)on top of the rear axle. Sometimes they get trash on the sensor and give a bogus signal back to a module under the dash for your speedometer. Most of the time, cleaning or replacing the VSS will fix your problem. Hope this helps. ---RED
61coon
61coon
Post  glenevans January 5th 2015, 1:07 pm
Thanks Red, I'll check it out tonight - Glen
glenevans
Post  bbf-falcon January 5th 2015, 2:21 pm
61coon wrote:The first thing I would check is the VSS (sensor)on top of the rear axle. Sometimes they get trash on the sensor and give a bogus signal back to a module under the dash for your speedometer. Most of the time, cleaning or replacing the VSS will fix your problem. Hope this helps. ---RED
X2
Post  glenevans January 5th 2015, 2:50 pm
Thanks guys!!!
glenevans
