Needing intake manifold advice
Background:
1979 f150
460, 770 Holley vacuum secondaries, performer 460 intake
Stock C6
3.50 gears
38.5 tires
I'll be picking up a recurved distributor, straight up timing chain and headers in a couple days.
My question is will I benefit from a Weiand Stealth 8012 Intake Manifold?
Thanks, Brandon
1979 f150
Stock C6
3.50 gears
38.5 tires
Thanks, Brandon
Brandon D- Posts : 6
Re: Needing intake manifold advice
I would look at the gear tire combination before the intake
FalconEh- Posts : 1448
^^^^^^this
gmsmkr- Posts : 1364
Brandon D wrote:Background:
1979 f150
Stock C6
3.50 gears
38.5 tires
Thanks, Brandon
ONLY at Wide Open Throttle and lose everywhere else.
FalconEh wrote:I would look at the gear tire combination before the intake
5.13's and a full spool for the rear are on the list.
That's what I figured.
Would I benefit from any other manifold? Say, a Performer RPM?
Intake gasket is leaking so I figured I'd swap it while I had it off if I would see any gains.
The rpm would work fine IMO
Is it a stock low compression 460?
dfree383 wrote:The rpm would work fine IMO
Yes, except for intake and carb, stock motor with D3 heads.
If you have no intention of raising the compression ratio from the factory 7.9/1 ... keep the regular Performer and just put a 2", 4hole spacer under the carb.
» New to 460's, needing advice
» Intake Manifold For 598 A-460
» Advice re inlet manifold to suit 521
» Intake manifold design ~vs~ Intake air temp.
» Need intake and cam advice
