#1 Main bearing oil hole
The front main bearing hole seems to be outward of the oil slot in the main bearing. (see pic)
Do I need to oval the small hole towards the center to allow the front cam bearing to get more oil? Notice the #2 bearing slot is over both holes.
Bob
Tucson
Bob
Tucson
75truck- Posts : 102
Re: #1 Main bearing oil hole
That is normal . Although not necessary I believe , I do chamfer the hole slightly
Gregaust- Posts : 626
75truck wrote:The front main bearing hole seems to be outward of the oil slot in the main bearing. (see pic)
Bob
Tucson
The oil is also fed by the big hole on number one so it is no problem as it is...
DaveMcLain- Posts : 399
If you are concerned about the center hole to the cam bearing you can completely block it on number1 if you wish because, it is fed oil from the other side.
Don't bother chamfering it. As dave and Randy have both said, it gets plenty of oil from the big galley going across the front of the block.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Ok no need to enlarge!
Thanx guys - now that the kind of experience that really helps.
Thank you,
Bob
Tucson
Thank you,
Bob
Tucson
» REAR MAIN - WHAT HOLE TO PLUG?I
» rod and main bearing's
» what main bearing
» main bearing gap
» Rod and main bearing .
» what main bearing
» main bearing gap
