Good safe place to start with base timming ?
+7
kim
gmsmkr
DaveMcLain
whitefield
11 posters
Page 3 of 3 Previous  1, 2, 3
Good safe place to start with base timming ? - Page 3 Empty Re: Good safe place to start with base timming ?
Post  IDT-572 July 14th 2015, 9:26 am
Mark Miller wrote:
bbf-falcon wrote:It shouldn't turn over hard w/strong Batt. hitorq starter and good cables. Something is missing.
X2,i don't even have a hi torque mini starter.I have the regular old school starter with the starter solenoid in the engine compartment by the battery and never have starting issues.466 ci SRP flat top piston and Aluminum A-429 heads with timing at 22 initial and 35 total.
Something is not right, he will find it , just needs more time.
Post  supervel45 July 14th 2015, 8:02 pm
whitefield wrote:
IDT-572 wrote:With the engine hot and the oil thin the plunger will go down on a hydraulic lifter if stopped at full lift. Is it making noise while running? And are  any of the rocker arms not opening the valve as far as the rest (lobe down)?
20 lb idling is ok as long as it comes up with rpm.
Yes oil pressure goes up when throttled , it is noise up top but not as loud as a solid flatt tappet cam. Looks like one on number 8 exhaust valve not opening the valve as much as the others.
Is the rockerarm loose?
Post  gmsmkr July 14th 2015, 8:18 pm
I want to say it's prolly a ground seeing a new harness was installed
gmsmkr
gmsmkr
Post  whitefield July 25th 2015, 6:21 pm
Update got it sorted out today ! Embarassed Bad distributor cap and one valve or rocker arm out of adjustment !
Thanks For all of the help I really appreciate it !!!!!! Very Happy
whitefield
whitefield
Post  maverick July 25th 2015, 6:23 pm
cheers cheers cheers
Post  supervel45 July 25th 2015, 6:36 pm
Glad to hear it. Cool
Post  IDT-572 July 26th 2015, 10:35 pm
Wink
