Blown C head
+12
keith hunter
4thHorseman
gmsmkr
crittersf1
butterbean
Snowball Racing
16 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Re: Blown C head
is it for you??
butterbean- Posts : 676
Re: Blown C head
ok cool Robert, I'll see you at the track
Re: Blown C head
Cool lets see some details
Re: Blown C head
I am taking my existing 605 that will go 4.40's @155 in south florida heat.
putting a 1471 with 2 terminators.
Wilson Manifolds is making a manifold for me, which will open the door for others that want to build one, as no one makes an intake for C heads
So, basically just taking some lift out of cam, lowering compression and putting the huffer on.
Snowball Racing- Posts : 85
Re: Blown C head
Impatiently waiting for results on this one.
crittersf1- Posts : 521
Re: Blown C head
is this going into the 69 Mach 1 in your aviator
Re: Blown C head
going for low qualifier in Q-16 at 1 of our tracks?? this build will be cool for sure, I know we have a pro-charged Dragster that runs just barely faster than Robert's N/A car now so it looks like its on now!!!!!!!!!!
Re: Blown C head
Snowball Racing wrote:Yea, I'm putting one together.
gmsmkr- Posts : 1364
Re: Blown C head
Robert,
I would suggest that you buy another crankshaft. The blown engines like the BB Chevy crank snout diameter, and of course double keyed. Your front motor plate needs to be reworked and design in a crankshaft snout support bearing, such as what RCD makes for the Hemi and Chevy engines. The crankshaft should probably have center counterweights and then your rod journals need to go back up in size to 2.375" and run the Chrysler bearings. Also, it will be time to switch to a cam gear drive with a cam driven mechanical fuel pump such as Enderle or Waterman. It's time for a magneto also.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Re: Blown C head
wow !!!! she is gonna be a beast
Re: Blown C head
That thing is massive! ...that's what she said
4thHorseman- Posts : 400
Re: Blown C head
Updates? More pics?
Re: Blown C head
Wilson mainfold has everything. It will be a few months for them to make the intake out of a solid block of aluminum. They are designing it from scratch.
Re: Blown C head
BigBlockFalcon wrote:Wilson mainfold has everything. It will be a few months for them to make the intake out of a solid block of aluminum. They are designing it from scratch.
That should be some major engine porn!
c head blower manifold
i have a new Hogan c head blower manifold , ive decided to go a diffirent direction so I wont be needing it
keith hunter- Posts : 4
Re: Blown C head
keith hunter wrote:i have a new Hogan c head blower manifold , ive decided to go a diffirent direction so I wont be needing it
We need pictures!
Re: Blown C head
Re: Blown C head
BigBlockFalcon wrote:Mocking stuff up
Awesome, Is it going in the Falcon ?
FalconEh- Posts : 1448
Page 1 of 2 • 1, 2
» Blown head gasket
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» coolant leak between head and block at head bolt location.
» roots blowers
» roots blowers
Page 1 of 2
