How fast in unwelded axle tubes?
Soooo do any of you have some numbers on how fast you've been with unwelded 8.8 tubes?
I just got my rear together. Team z strip series uppers, team z lowers, team z arb, strange pro race axles 33 spline, spool, and 4.30 gear.
Motor is relatively mild to what a lot of you are running. Somewhere between 10.5-11/1 compression. .530 lift cam, 280 duration. Ported, bigger valved c8's. Nothing fancy. Will be a footbrake car with a c6. Don't know what converter yet though. Probably won't until next spring when I actually have the money.
I'm just curious if I can get by with bracing to keep twisting and deflection down or if I need to have those welded to center section. I actually was going to have speed shop here in cincinnati weld them a few days ago but they said they didn't have the right pucks for the housing ends for the jig which I thought was weird seeing as to how common this rear end is, but I'm just exploring my options. Thanks in advance.
Foxfire85- Posts : 35
Re: How fast in unwelded axle tubes?
9.90's but that was eon's ago when it was a small block on a small kit. Never waited around until they did. With the torque of the BB I would be careful, even at your power level. That being said the 8.8 can take a TON of power if braced correctly, at least in my experience.
yellowhorse7- Posts : 1382
yellowhorse7 wrote:9.90's but that was eon's ago when it was a small block on a small kit. Never waited around until they did. With the torque of the BB I would be careful, even at your power level. That being said the 8.8 can take a TON of power if braced correctly, at least in my experience.
Yeahhhhhh, I feel you man. I think I know deep down I need to just pull it out and have it welded. Less of a hassle I'm sure than spinning or cracking a tube. Can you recommend proper bracing techniques for me? Even in addition to welding? I'd like this thing to live a while. It seems to be an argumentative topic for guys to want to say some bracing does nothing in certain configurations where in other configurations it can be very effective.
Thank you for the reply, btw
» Tubes & slicks
» thank god for tubes....
» Tubes no Tubes
» M/T tubes
» how do people feel about torque tubes???? 18 inch
» Tubes no Tubes
» M/T tubes
