Junkyard dog
gmsmkr
Junkyard dog Empty Junkyard dog
Post  gmsmkr October 25th 2015, 8:44 pm
I'm putting together a all used parts( other than gaskets ) 460ci combo all parts will be CHEAP or FREE from board members and friends.
Parts I have:
D1VE block stock bore
Full set of EFI pistons on truck rods
Front sump oil pan
A comp hft cam can't remember specs
Efi timing set
Stock main bolts and head bolts
Parts I need:
Rings
Bearings
Intake
Carb
Distributor
Heads
Gaskets
I will post pics when I dig all the parts out and get them from sources.... I will put this engine on the dyno so we can see just how much power can be made with really cheap & free parts with ford crank, rods and pistons... then we will throw a small shot of nitrous to it Very Happy
gmsmkr
gmsmkr
Junkyard dog Empty Re: Junkyard dog
Post  supervel45 October 25th 2015, 11:36 pm
We gotta have the cam specs. to make it any fun. If they are under 230 it probably won't start you know.
Post  supervel45 October 26th 2015, 4:21 am
https://www.429-460.com/t23312p60-cam-change-what-to-expect Call Straub and see if he will cut a cam for the experiment. It would make for a cool test if you have the dyno time.
Post  gmsmkr October 26th 2015, 9:05 am
I'm not going into custom stuff with this just because I will let the young guys assemble it. I want cheap stuff so no dumping $ into stuff and they can see how easy it is when shopping around for decent parts.
But mostly how to tell if they are getting usable parts not just some junk that is out of spec..
gmsmkr
gmsmkr
Post  supervel45 October 26th 2015, 9:42 am
Sounds like a pretty cool deal all around, and glad to see someone still playing with factory iron. Can't wait to see how it turns out.
Post  gmsmkr October 26th 2015, 10:54 am
The cam is a xe274 grind 230/236@.050
we can make around 450hp with the right parts selection and a good dual plane with a 850 carb.
I will start digging parts out this week I have some that are out of spec and some that need lots of work to be usable but this is where the fun part starts cause I will check them all my self then let them check them and see if they can pick the best usable parts and let them pick cam and heads to make the power.
gmsmkr
gmsmkr
Post  supervel45 October 27th 2015, 2:29 am
Might as well run that 274 since you have it and see how it does.
Junkyard dog Empty Just a update
Post  gmsmkr December 4th 2015, 10:56 am
I will get pics this weekend of all the parts so far..
The block will need to be bored and the crank turned so that will be the biggest expenses just going to get some 40 over pistons and prolly a set of PRO COMP heads just to loose some weight.
This will be backed up with a c4 3000 stall with 4.30 gear and a 28x10.5 tire and all this is going in a 1986 mustang convertible..... Car pic to come
gmsmkr
gmsmkr
Post  bigben December 5th 2015, 7:01 pm
Really interested to see what you think of the pro comps I argued with my self about buying a set over working a set Of dove heads
bigben
Post  gmsmkr December 6th 2015, 5:01 pm
bigben wrote:Really interested to see what you think of the pro comps I argued with my self about buying a set over working a set Of dove heads
The pro comp is no race head and needs lots of work to even compare to DOVE heads with little work.... JMO on pro crap
gmsmkr
gmsmkr
Post  FalconEh January 1st 2016, 7:00 pm
BumP
Post  gmsmkr January 2nd 2016, 12:04 am
This is the car ... block still on stand and parts in parts washer just need to make the time to help them get it started
Junkyard dog 20160101_103252_zps698ecikv
gmsmkr
gmsmkr
Post  FalconEh February 8th 2016, 12:24 am
Bump Basketball
Post  gmsmkr February 8th 2016, 12:38 am
Parts are at machine shop... now it's a waiting game I told him to work it in when he has slack time
gmsmkr
gmsmkr
Post  Bill Heard February 8th 2016, 1:29 am
What are you doing for heads?
Bill Heard
Bill Heard
Post  gmsmkr February 8th 2016, 9:18 am
Still trying to decide on heads
gmsmkr
gmsmkr
Post  gmsmkr March 26th 2016, 12:40 am
Update on this build
D1 block 30 over
Dome top pistons on truck rods
Stock crank turned 10-10
Dove heads with screw in studs and guide plates
Solid flat tappet cam
Electric water pump
Roller rockers and pushrods
All parts are here now only thing left is bearings, rings and gaskets the static compression should roll in around 13
Pics to come
gmsmkr
gmsmkr
Post  gmsmkr March 26th 2016, 12:45 am
Junkyard dog 20160325_133218_zpsr1qqonzf
Junkyard dog 20160325_134242_zpsyhibr5fz
gmsmkr
gmsmkr
Post  Wish4svts April 23rd 2016, 9:47 am
What brand Pistons? What fuel are you planning to run? What intake do you have? Very interested in this build as I hope to do something similar shortly.
Wish4svts
Post  gmsmkr April 23rd 2016, 11:59 am
Wish4svts wrote:What brand Pistons?  What fuel are you planning to run?  What intake do you have?  Very interested in this build as I hope to do something similar shortly.
TRW dome top forged , AV gas , victor 460 4150 pad , it's on the back burner the convertable was sold we will find another chassis when it gets built
gmsmkr
gmsmkr
