How much can you turn a crank?
I got a crank and it's already .010 on the rods, .020 on the mains. Is the anything wrong going to .030? It will be around a 550hp build, and race only and didn't know how the thicker bearings would hold up.
YellowStangDuane- Posts : 76
Re: How much can you turn a crank?
It will be fine as long as you can get bearings in the size.
I think I've seen .040's
YellowStangDuane wrote:I think I've seen .040's
How about .300" under; (and even more) ... all the time.
rmcomprandy wrote:YellowStangDuane wrote:I think I've seen .040's
Yes but when you turn it .300 under on the rods the bearings are STD again!
DaveMcLain- Posts : 399
Yes they are! So I guess thicker bearings are not an issue in my case...
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» New motor won't turn over
» 611 ci, 9000 rpm. Turn it up!
» When to turn on the NOS?
» C6 won’t turn
» C6 won’t turn
