611 ci, 9000 rpm. Turn it up!
+10
68galaxie
Straubtech
samiam
14 posters
 611 ci, 9000 rpm. Turn it up! Empty 611 ci, 9000 rpm. Turn it up!
Post  Scott Foxwell July 10th 2016, 6:48 pm
Turn it up!
https://www.facebook.com/shannon.wiebe.1/videos/1223606181024364/
 611 ci, 9000 rpm. Turn it up! Empty Re: 611 ci, 9000 rpm. Turn it up!
Post  billandlori July 10th 2016, 7:38 pm
Wow, what a sound!! I'm just gonna listen a few more times....
Bill
Post  dfree383 July 10th 2016, 8:38 pm
Nice
Post  samiam July 10th 2016, 11:08 pm
thats flat screamin, sweet
samiam
samiam
Post  Straubtech July 11th 2016, 9:41 am
4 PULL's now and 4 wins.
Straubtech
Post  68galaxie July 11th 2016, 11:02 am
Very cool engine build.
What cam timing was eventually used? I hear it was less than .900" lift.
I also assume reasonably tame lobe profiles as dictated by high rpm range?
Like to hear some "tech" .
Cheers
68galaxie
68galaxie
Post  Straubtech July 11th 2016, 11:20 am
68galaxie wrote:Very cool engine build.
Cheers
This engine has 60MM cam journals and .937" Key way lifters. Camshaft is:
.894/.880
288/319 .050
112 LSA
Straubtech
Post  cletus66 July 11th 2016, 12:17 pm
That thing is singing !!! How long does something like that last before a refresh with new springs, etc?
Post  Frank Merkl July 11th 2016, 1:40 pm
Music to my ears!!!
Post  68galaxie July 11th 2016, 2:48 pm
.894/.880
288/319 .050
112 LSA
Thank you Chris!!
The duration split sure works well. I sometimes think many do not go far enough - certainly N/A.
Thanks again for the info!
68galaxie
68galaxie
Post  IDT-572 July 11th 2016, 5:21 pm
79.5 degrees of overlap.................. I like it. Cool
Post  Straubtech July 11th 2016, 5:28 pm
IDT-572 wrote:79.5 degrees of overlap.................. I like it. Cool
It put 30' on a Hemi headed Ford over the weekend.....Not bad for a Wedge head engine...
Straubtech
Post  IDT-572 July 11th 2016, 5:32 pm
Check your PM's
Post  Lem Evans July 11th 2016, 6:00 pm
I doubt it was a Kentucky bred Hemi Ford Very Happy
 611 ci, 9000 rpm. Turn it up! Boss001Medium_zps712b900f
Post  Straubtech July 11th 2016, 6:11 pm
Farther West.....MO.
Straubtech
Post  Lem Evans July 11th 2016, 6:33 pm
David Garrett slayed many Sonny's & Schmidt units to win the 2015 NTPA region IV 4X4 modified chanpionship
 611 ci, 9000 rpm. Turn it up! One%20more_zps9mcii4vt
Post  Lem Evans July 11th 2016, 6:51 pm
Black valve covers were worth 37 lb. ft. @ 7850 rpm Idea
 611 ci, 9000 rpm. Turn it up! BLACK_zps3zmzdueg
Post  Straubtech July 12th 2016, 9:44 am
Lem Evans wrote:David Garrett slayed many Sonny's & Schmidt units to win the 2015 NTPA region IV 4X4 modified chanpionship
Good looking truck Lem. What's the "ticulars" on that engine?
Straubtech
Post  68galaxie July 12th 2016, 9:58 am
I suspect a large suitcase full of $1000.00 bills.
Awesome to see these high value builds - usually top secret
Cheers
68galaxie
68galaxie
Post  Lem Evans July 12th 2016, 10:32 am
High dollar heads and manifold for sure but, so is a CFE Thor package.Smile
The interesting thing about this deal is it's still the same A460 block, stef's pan and tank, Danny Bee, coil, dry sump pump that I sold him about a dozen years ago when it was a 514" 1X4 C460 package.
  611 ci, 9000 rpm. Turn it up! Garrett%203_zpsh3jntrsq
Post  Scott Foxwell July 12th 2016, 7:29 pm
cletus66 wrote:That thing is singing !!!  How long does something like that last before a refresh with new springs, etc?
This engine has 30 dyno pulls and 4 competition pulls (four wins) all in the 8000-9000rpm range. It's due for valve springs and they have a clear view oil filter in the truck and it's as clean as a whistle. Bottom end should be good for the season. Valve train was built for 9K rpm duty. All stainless T&D rockers, REV Ti valves, PAC springs and retainers, geometry is spot on, Smith Bro's 1/2" push rods, .936 DLC coated keyway lifters in CHE bushings and like Chris said, 60mm cam. It took many many hours to get the heads to where they were ready to bolt on. Almost every part on this entire build had to be modified, trimmed, fixed, tweaked, etc. I got pretty frustrated a few times but the effort was worth it.
Post  68formalGT July 12th 2016, 9:11 pm
Lem Evans wrote:High dollar heads and manifold for sure but, so is a CFE Thor package.Smile
Lem, what bore and stroke was the 514?
Post  Lem Evans July 12th 2016, 9:16 pm
Long time ago....I don't recall the stroke. It was a 4.625" bore.
Post  68formalGT July 13th 2016, 2:38 am
Lem Evans wrote:Long time ago....I don't recall the stroke. It was a 4.625" bore.
I bet that was a screamer!! Should be just under 3.85" stroke.
Post  Frank Merkl July 13th 2016, 2:56 am
are's with a 4.625 stroke @ 9000 rpm, we've had dragsters shutoff because they couldn't heard there motor at the 1000ft mark because when we come up on the they thought they had blown up!!!LOL
