flywheel weight position?
flywheel weight position?  Empty flywheel weight position?
Post  Bart Knox November 21st 2015, 12:55 am
We installed the motor tonight on the f100 we've been working on. The flywheel had been sitting around for a while hard to make out the the circle from the hole in crankshaft tried to clean the rust off but hard to tell. We already installed it and the transmission is in. Should the weight basically be lined up with the weight on the harmonic balancer?
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
flywheel weight position?  Empty Re: flywheel weight position?
Post  cool40 November 21st 2015, 3:07 am
If all the bolts went in you're good to go. Cool
Post  Gregaust November 21st 2015, 5:04 am
Bolt holes will only line up in one position Wink
Gregaust
Post  crittersf1 November 21st 2015, 9:11 am
Gregaust wrote:Bolt holes will only line up in one position Wink
What he said!^^^^^
crittersf1
crittersf1
Post  Bart Knox November 21st 2015, 10:14 am
I asked a few people last night though we were all sort of mechanicaly inclined guess not. Put about 10 flywheels on motors don't know how I never figured that out thanks guys guess it went together good:oops:
Bart Knox
Bart Knox
