Post Your bracket racing secrets!
+11
99zx9r
Larry Williams
514F-1
70FB
83-88T-Bird Guy
D. Sea
whitefield
away
15 posters
Let's hear them! Lets beat on them chebby boys this year!
Examples like:
Spragless converter, tire pressure, temps the same (water and trans), shift with time vs rpm, alcohol injection, timing backed off a little, line-loc tied in with trans brake, logging runs, weather station tricks for E.T prediction etc....
Lets build a list of things everyone does to win at bracket racing and lets help put the BBF's in the winners circle.
Examples like:
away- Posts : 266
Re: Post Your bracket racing secrets!
My secret is I dont enter bracket races.
Cut an awesome light and run on your dial every time, ain't no big special secret!!!! It's all about being consistent and predictable
away wrote:Let's hear them! Lets beat on them chebby boys this year!
Examples like:
I run or do everything above other than spragless converter. I also run true street classes and heads up classes .
whitefield- Posts : 2244
Practice Practice Practice and consistent starting line procedures. Some like to hole a few numbers like .02-.04 and drive the stripe.
BTW: I'm next door to you in Lawrenceburg. Where do you usually race? When I can, I usually go to MP Dragway.
D. Sea- Posts : 2768
On both of my e.f.i. bracket cars, the water temp is probably the biggest variable as to the e.t. it runs, so I watch the exit temp of the coolant.
83-88T-Bird Guy- Posts : 1003
Air temp/ humidity/DA
70FB- BBF CONTRIBUTOR
Examples like:
Im not the greatest bracket racer in the world, but here are a few things that I do.
-check tire pressure before every pass to make sure that its right on the money
-keep the water temp at the some temp every pass
-Keep the same amount of fuel in the car for every pass.
-log runs and keep track of the weather (I need to get better at this myself)
_Keep your routine the same, me personally, I like to get in the car and get strapped in a ways back, so that im not rushing to do that when Im two pairs from the front.
-From what I have heard Alky will make most cars more consistent, but I have no real world experience with it.
- I also find that its best to not run the car on the ragged edge, keep it backed down a little, maybe a couple tenths or so from what it can do all out, and it will be a little more consistent, at least mine is. Few degrees low on timing, shift a little below peak etc. also helps your stuff last longer....remember it doesnt matter how fast you go its all about consistency....
-also, a big thing, DONT MAKE CHANGES TO THE CAR!! In order for things to remain consistent, you cant keep tinkering with the car all the time, set it and leave it alone, I haven't changed the launch RPM, Shift RPM, Jets, etc in over 2 years.
Hope this helps, like I said, im not very good at this stuff, but I enjoy it and am always looking to get better, so keep the advice coming
![Very Happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png)
514F-1- Posts : 242
I use an STL
Larry Williams- Posts : 884
For footbrakers, don't be afraid to try deep staging. Many racers are surprised to learn that their cars just don't react quick enough to cut a good light shallow staged (without anticipating). I swore my Mustang running 9.2s could hit the tree shallow, but when I tested on the .500 Pro Tree (which is the best way to tell if you're anticipating) the best I could do was .050.
99zx9r- Posts : 39
^^^^^^ The above mentioned (mostly)
Plus;- be ready early 6-cars back strap in don't talk to others, focus on my routine
- watch the tree and practise the lights when other cars are leaving
- slowly and carefully stage the same every time
-Backup button of juice for wheelspin fender racing
FalconEh- Posts : 1448
What's a bracket race
my track quit bracket racing said they make more money off grudge racing and don't have to pay any money out
![Question](https://2img.net/i/fa/i/smiles/icon_question.gif)
gmsmkr- Posts : 1364
Pick out two or three guys that win regularly and just be observant of things they do, on and off the track. I learned a ton from just hanging around the right people when I first started.
Learn how to stage your car exactly the same every time. It's amazing to stand at the starting line to watch people not be able to stage their car correctly.
BigDave65- Posts : 567
Larry Williams wrote:I use an STL
^^^^^what is this?
away- Posts : 266
away wrote:Larry Williams wrote:I use an STL
^^^^^what is this?
I'm guessing it's the "Shoot The Light" transbrake trigger.
99zx9r- Posts : 39
The only real secrets in br is the guy with a hidden box etc. A new br shouldn't ask for secrets.Just good advice from a veteran.. Seat time is your best friend.He will show you the little tricks about cutting a light and racing the stripe.come to the Bash as US 60 in june,Dan Hobbs will be puttin on a clinic AGAIN.
99zx9r wrote:away wrote:Larry Williams wrote:I use an STL
^^^^^what is this?
you guessed it works great on a pro tree
Hell, I just Lucky now and then Rick..........bbf-falcon wrote:The only real secrets in br is the guy with a hidden box etc. A new br shouldn't ask for secrets.Just good advice from a veteran.. Seat time is your best friend.He will show you the little tricks about cutting a light and racing the stripe.come to the Bash as US 60 in june,Dan Hobbs will be puttin on a clinic AGAIN.
![Cool](https://2img.net/i/fa/i/smiles/icon_cool.gif)
![king](https://2img.net/i/fa/i/smiles/icon_king.png)
56Tbird- BBF CONTRIBUTOR
» Bracket racing
» The Drag(ster) slayers
» NMRA Bowling Green, KY racers...no more Bracket 1 or BK 2
» Bracket racing
» Pulled the wheels a little yesterday bracket racing
» Bracket racing
