205 transfer case question...
I have an idea... I have not worked with a 205 before..
My question is when you are in low range where are the two rods? In or out...? i want to make a bracket that holds the transfer case in 4 low and remove the shift lever totally ... can someone tell me where the two rods should be positioned?
racinghabbit- Posts : 575
Re: 205 transfer case question...
I beleve they are both in for lo.
http://www.pirate4x4.com/forum/general-4x4-discussion/572617-how-np-205-twin-stick-cheap.html
68formalGT- Posts : 865
No need for a bracket to hold it in low. Push both rods in completely and run it. This has been done for years
lghting94- Posts : 762
» Which automatic transmission and transfer case
» Cleaning up the Transfer Case
» "Transfer Case Rebuilder ?"
» 79 bronco transfer case ?
» Pro_Fab type 205 transfer case
