? Block ID
? Block ID Empty ? Block ID
Post  Inthegarage April 1st 2016, 10:20 am
Can a D1VE block be a 429 ? Fellow has one but I haven't had a chance to mic the bore.........Thx
Inthegarage
? Block ID Empty Re: ? Block ID
Post  dfree383 April 1st 2016, 10:37 am
Yep..... And it's the stroke that makes a 429 3.59, the bores are the same on a 429-460 4.36.
460 stroke is 3.85
Post  gmsmkr April 1st 2016, 10:39 am
Beat me to it....x2
gmsmkr
gmsmkr
Post  Paul Kane April 1st 2016, 12:08 pm
Inthegarage wrote:Can a D1VE block be a 429?
In 1971, 1972, and 1973 model years, typically.
Post  supervel45 April 1st 2016, 8:22 pm
My 429 has a D1VE block with D2 heads and started life as a 2 barrel likely from a Mercury. The pistons where small dish 12-14cc and about 8.5/1 compression even at over .040" in the hole by the compression calculator.
? Block ID Empty Thanks
Post  Inthegarage April 1st 2016, 8:41 pm
Thanks for the info Guys.....Picked up parts today and now have more questions....1 block is D1VE A2 and the other D1VE A2B...BUT the cranks are 4U and 2YABC
If I read things correctly 1 is a 429 and 1 is a 460.............Am I correct on this ? Thx again
Inthegarage
Post  supervel45 April 4th 2016, 9:18 pm
Inthegarage wrote:Thanks for the info Guys.....Picked up parts today and now have more questions....1 block is D1VE A2 and the other D1VE A2B...BUT the cranks are 4U and 2YABC
Yes 4U is 429 (all 429's are internal balance) and 2Y is internally balanced 460.
Post  Inthegarage April 4th 2016, 9:48 pm
Thanks again
Inthegarage
Post  supervel45 April 4th 2016, 10:19 pm
So what you gonna do?
Post  Inthegarage April 4th 2016, 11:00 pm
Going to build a 429 and a 460................
Inthegarage
Post  supervel45 April 4th 2016, 11:42 pm
Inthegarage wrote:Going to build a 429 and a 460................
LoL that's what I meant, which one.
